Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Forum Newbie
    Surveying
    Civil 3D 2017
    Feb 2018
    3
    Default used layers in an empty dwt
    I've been building a template and the layer manager shows 8 used layers and I can't figure out why there should be ANY used layers. I'd like to clear these so that when I do start a dwg with my template the used layer filter will truly show me just the used layers.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,163
    If it is showing them used there is probably something somewhere on those layers, maybe a stray line buried in a title block on a layout. or viewport on an odd layer, maybe a text style or dimension style has it in use in the settings, if things like that don't show up immediately then most often it would be inside a block somewhere. Post the file if persists in being elusive.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Forum Newbie
    Surveying
    Civil 3D 2017
    Feb 2018
    3
    I tried a purge all (not fully understanding what the results would be) and of course all the layers were deleted, not the result I was looking for. Undo restored all the layers but now ALL the layers show up in the All Used Layers filter. **sigh**
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,163
    Ahh that's different, if the layers purge then they aren't used, you need to change the variable showlayerusage=1 here's a description UsedLayers and then change filters a couple of times for it to kick in
  5. #5
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    LAYDEL is my friend. And LAYMRG to 0.
  6. #6
    Forum Newbie
    Surveying
    Civil 3D 2017
    Feb 2018
    3
    I'm down to 6 unused layers including 0, which my filter shows as being used. I guess I'll live with it, seems like I'm always settling to "live with it" in Civil 3D. LDD was much more surveyor friendly.
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    It may be a civ3d style setting these are a bit harder to check as there is so many.
  8. #8
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,124
    I have moved your thread to the Civil 3D & LDD Forum.
  9. #9
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,211
    Something I always wanted in Civil 3D was a layer checker. If you couldn't purge a layer, this code would find what was using it. That way you didn't spend hours clicking through styles for surfaces, points, contours, profiles, assemblies, tables, etc. etc. etc.
    breaking AutoCAD on a regular basis since 1991
  10. #10
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    825
    Deleting layers and importing Survey data afterwards could become a problem. I have an assortment of templates for every occasion. From my signature below "So many issues can be solved with good templates."
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  1. Empty layers, Hide Turn off or (Show only layers that contain objects)
    By PSAPmapR in forum AutoCAD Drawing Management & Output
    Last Post: 18th Nov 2013, 04:14 pm
  2. Cad Annoyances: empty blocks, persistant layers, block with far away basepoint
    By nicolas in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Apr 2011, 06:06 pm
  3. deleting empty layers
    By reyems in forum AutoCAD Beginners' Area
    Last Post: 9th Jan 2010, 11:40 pm
  4. [A2007] can't delete empty layers
    By BoHiCAAA in forum AutoCAD Drawing Management & Output
    Last Post: 21st Nov 2007, 07:41 pm
  5. I can't delete or purge layers that I believe are empty
    By firepoiboy in forum AutoCAD Drawing Management & Output
    Last Post: 7th Feb 2006, 05:10 pm
