Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member
    AutoCAD 2015
    Aug 2015
    18
    Default block to stay centered while stretching
    Hi guys,
    I'm trying to have the base point of this block centered so when i put this window in a room, i could change the size without readjust the window back to the center of the room?
    i know i could have 2 stretch actions to stretch both sides but i want the full window opening size to be shown at the bottom while im stretching.
    any ideas?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,159
    Change the basepoint of the distance parameter in properties to the center and then add another stretch action at the left hand end (and move the insert point to the center of the block)
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,603
    If your happy with a manufacturers standard sizes then you can have a pop up of std sizes as part of the dynamic block rather than drag or enter width. Post if you want an example.
    Junior Member
    AutoCAD 2015
    Aug 2015
    18
    Quote Originally Posted by steven-g View Post
    Hi Steven,
    if i put the stretch midpoint will it show only half the distance or the full opening dimension which i am after?
  5. #5
    Junior Member
    AutoCAD 2015
    Aug 2015
    18
    @ Bigal
    interesting, can i please see an example?
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,603
    This was not done by me but a good example. I do apologise I dont have original contributors name.
  7. #7
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    Not sure about that dynamic bolt block because I don't believe it is setup to work with a midpoint stretch...
    Anyways, please take a look at the posted block and you'll see that I used a parameter set with 2 stretches. I placed the midpoint at 0,0 for simplicity. Don't forget to change the parameter properties to stretch from midpoint.
    Thanks.
    wintest.dwg
  8. #8
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,159
    Quote Originally Posted by Ibanezboy21 View Post
    Hi Steven,
    If you had bothered to try it you would see. I did try it so I know what it does.
  9. #9
    Junior Member
    AutoCAD 2015
    Aug 2015
    18
    Quote Originally Posted by iconeo View Post
    Thanks.
    Attachment 63345
    oh its that simple, thanks for posting an example.
    Seems like I've been doing it the wrong way all along....
  10. #10
    Junior Member
    AutoCAD 2015
    Aug 2015
    18
    Sorry Steven i did try it in the past but i think i was doing it incorrectly (using 1 grip for distance parameter instead of 2)
    i've learnt to make blocks using youtube videos so im still learning everday
  1. Replies: 7
    Last Post: 3rd May 2017, 06:21 pm
  2. stretching block
    By notredave in forum AutoCAD Drawing Management & Output
    Last Post: 12th Mar 2016, 03:31 am
  3. Keeping an object centered and stretched in dynamic block
    By artuiel in forum AutoCAD Drawing Management & Output
    Last Post: 25th Mar 2014, 05:41 pm
  4. Dynamic Block Stretching
    By j4jason83 in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2012, 03:15 pm
  5. Keeping text centered in a block
    By chelsea1307 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Feb 2010, 09:00 pm
