How to determine in which quadrant pt2 is relative to pt1
gsc
Heres something to investigate:
_$ (setq p1 '(10. 10. 10.))
(10.0 10.0 10.0)
_$ (setq p2 '(5. 13. -4.))
(5.0 13.0 -4.0)
_$ (setq p (mapcar '- p2 p1))
(-5.0 3.0 -14.0)
_$ (setq res (mapcar 'minusp p))
(T nil T)
_$ (setq res (apply '(lambda (a b c) (list a b)) res))
(T nil)
; +X +Y = 1st
; +X -Y = second
; -X -Y = third
; -X +Y = fourth
_$ (vl-some '(lambda (x) (if (equal (cdr x) res) (car x)))
   (1st nil nil)
   (2nd nil T)
   (3rd T T)
   (4th T nil)
4TH
Or just use the angle function for the p1 and p2, and determine with cond if its between 0/90/180/270.
  • 2 months later...
Hi, the codes of both Lee and Irm return q=3 where it should be q=4 for the folowing 2 coordinats...is this correct?
p1 (bpt) = 494487.36,5727352.41
p2 (pnt) = 494497.36,5725787.41
Modified: Sorry miscalculation...codes are correct
Edited by gsc
