Results 1 to 6 of 6
    Senior Member
    AutoCAD 2015
    Jan 2015
    136
    Default Move quotes position without modify quote points
    Hi there!
    I've a question.. Is it possible to move a dimension that share is position with the points it is quoting (you will understand better with the gif) without moving these points?
    Look at this example:
    Thanks!
    Dennis
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,209
    If by "quote" you mean dimension, you may be picking the endpoint of the dimension itself (i.e. where the measurement ends) rather than the dimension line. Unfortunately, if they're in the same place, it's difficult to pick one without picking the other. I don't know of any way to pick the dimension line independently if it coincides with the endpoint.
    Teachable moment--it's a good idea to keep the dimension line offset from the measurement. If nothing else, it keeps the dimension line from obscuring the thing it's dimensioning.
    breaking AutoCAD on a regular basis since 1991
    Senior Member
    AutoCAD 2015
    Jan 2015
    136
    Quote Originally Posted by CyberAngel View Post
    Yes I mean dimension, sorry!
    Unfortunately it's not mt drawing and I've to fix that in a fast way.. Looks like I've to quote all manually
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,606
    There should be some way of getting the distance arrow point v's the node point and adjusting this, its not obvious using dumpit. When clicked the 4 grip points come up. Looking at entget assoc 10 11 13 gave interesting answers.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    I grab the grip in the center of the Dim Text.
  6. #6
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,209
    Quote Originally Posted by SLW210 View Post
    I should have thought of that.
  1. Routine to move objects to absolute 0,0 position.
    By dblclkmatt in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jan 2014, 02:34 am
  2. Move object from mid between two points to mid between two points
    By notview in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Mar 2013, 08:24 pm
  3. Quotes within quotes when writing a lisp issue
    By ibanez_222 in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Jan 2012, 05:05 pm
  4. Sustain position of Annotative Blocks after a Move
    By tzframpton in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Jan 2010, 05:15 pm
  5. Move or align an object to an absolute position on a single axis only
    By Kenji in forum Tutorials & Tips'n'Tricks
    Last Post: 26th Aug 2009, 07:26 am
