Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    Junior Member
    Surveying
    AutoCAD LT 2018
    Feb 2018
    12
    Default 3d Roof solid problem
    Hi all, Im a 2d CAD user so looking at producing a 3d model from survey data, im trying to make the roof solid, I can do it when the pitch is just 3 points but when I do the other side and extrude the roof it just does the edges, I've drawn a 3dpolyline and change mode to solid, i just cant see where im going wrong, would be grateful for some help, cheers, added a couple of shots
    Junior Member
    Surveying
    AutoCAD LT 2018
    Feb 2018
    12
    Default 3d Solid problem
    Hi there, wondered if someone can help me, ive used 2D AutoCAD for over 25 years and just started looking at some 3D bits, we have captured some data in 3D and im trying to draw up the roof.
    I can extrude solids on the triangle section of the roof but when I do it in a 4 point shape it will only do the surface and the edges just move and not the whole peice, im not sure what im doing wrong? would be grateful if someone could take a look for me, cheers
    Ill try to add a couple of pictures
    Junior Member
    Surveying
    AutoCAD LT 2018
    Feb 2018
    12
    Junior Member
    Surveying
    AutoCAD LT 2018
    Feb 2018
    12
  5. #5
    Junior Member
    Surveying
    AutoCAD LT 2018
    Feb 2018
    12
  6. #6
    Junior Member
    Surveying
    AutoCAD LT 2018
    Feb 2018
    12
  7. #7
    AutoCAD 2013
    Nov 2011
    6,051
    Hello danHook, and welcome to the CADTutor Forum.
    If you are trying to Model in LT, you will have a hard time of it, as it is designed and sold as a 2D program.
    If you are trying to EXTRUDE linework, make sure that it is a CLOSED Polyline, if you hope to create a 3D Solid.
    The PRESSPULL command is much more forgiving, in that regard, totally random lines can be used, as long as they intersect, and a 3D Solid will be created.
    http://www.cadtutor.net/tutorials/au...nd-press-pull/
    We do have a resident LT Modeling Wizard on the forum, steven-g, who will likely chime in if he sees your thread. Understand that modeling in LT is definitely going against the flow.
    Please clarify the software being used.
  8. #8
    Junior Member
    Surveying
    AutoCAD LT 2018
    Feb 2018
    12
    Thanks for the welcome, that was quick!, sorry its full release AutoCAD, they are closed polylines, i've even redrawn them as 3dpolys, i've tried PRESSPULL also with not joy, it seems any shape with more than 3 points and different z values it will only create a surface and not a solid, I have also changed the mode on Extrude to solid
  9. #9
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,159
    Someone mentioned my name! Hi Dadgad.
    There is no extrude in LT so if indeed that is the program you are using I imagine you are talking about thickness, and thickness only works straight up (UP is determined by the ucs Z direction) what it can't do is taper up so thicken will only ever work to create a rectangular appearance (or rhomboid if you start using 3D points for your line work. I'd be interested to know how you have created the triangles because to the best of my knowledge thats not using thickness, perhaps the solid command? Could you describe exactly what you are trying to do and how you are going about it and possibly attach the dwg file as an example.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  10. #10
    AutoCAD 2013
    Nov 2011
    6,051
    Quote Originally Posted by danHook View Post
    Needless to say, three points will always be COPLANAR, presumably the four points which you are trying to use are not, whence the fly in the ointment.
    Forgive me if that is not the situation, sounds like it might be.
    Are you at liberty to post the actual .dwg file?
    Lots of other ways to skin this cat, but a .dwg might be worth as many as 20 posts, enabling anybody with the spare time to cut to the chase.
  1. How best to construct this roof as a 3d solid?
    By fourleafclover in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Jan 2012, 09:14 pm
  2. Roof problem on L shaped building
    By Bogbadbob658 in forum Architecture & ADT
    Last Post: 21st Nov 2011, 12:46 pm
  3. 3d roof problem
    By webguit in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Nov 2009, 02:56 pm
  4. hovvering roof problem
    By rash in forum Architecture & ADT
    Last Post: 23rd Jul 2008, 06:05 am
  5. Roof problem when exported to 3dsmax
    By damob23 in forum 3D Modelling
    Last Post: 25th Jun 2008, 09:02 pm
