Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
  1. #21
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    For simplicity's sake I usually loft pitches individually so that if I need to make a change everything isn't one big single solid model.
  2. #22
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    320
    Regular lines work just as fine (since you only need the 2 sloped side lines to make a single roof pitch with LOFT).
    I use 3D on a montly basis, but the LOFT command was not know by me. This thread made me aware (used extrude 99/100 times), and opens up a world of new possibilities .
  3. #23
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Yes, you can loft lines but the result will be a surface not a solid. To achieve a solid one would have to then use the Thicken command.
  4. #24
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,661
    Well you can tell the Loft to be a solid in the mode options (201. I would honestly use something else for this task, maybe something like BricsCAD Shape. It reads/writes DWG files. Might be worth a shot and it only costs you some time as it is free.
    I would use SketchUp myself. If you have a full copy of AutoCAD you can install AutoDesk's free SKP import utility and make your model in SketchUp Make 2017 and then import the SKP into AutoCAD. Now the model will be surfaces and NOT a 3D solid, if that makes a difference.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  5. #25
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    f700es: I'm not sure I agree with you. If you were to loft two lines, even with the mode option set to solid, the result would still be a surface.
  6. #26
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,661
    Already did before I posted....... not lines but shapes. Perhaps that's the difference then.
    Edit:
    Perhaps that's my error in my approach to this. I would not use lines but shapes to construct the roof as I would try to solve this in a non AutoCAD way.
  7. #27
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    On that point, shapes, we are in agreement as long as they are closed polylines.
  8. #28
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,661
    +1 on the closed plines!
  9. #29
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    My $0.05 PFACE ! can have as many points a you like it makes a planar surface so hide, render etc will recognise it. Very suitable for roofs with valleys etc. The code is copyrighted.
  1. How best to construct this roof as a 3d solid?
    By fourleafclover in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Jan 2012, 09:14 pm
  2. Roof problem on L shaped building
    By Bogbadbob658 in forum Architecture & ADT
    Last Post: 21st Nov 2011, 12:46 pm
  3. 3d roof problem
    By webguit in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Nov 2009, 02:56 pm
  4. hovvering roof problem
    By rash in forum Architecture & ADT
    Last Post: 23rd Jul 2008, 06:05 am
  5. Roof problem when exported to 3dsmax
    By damob23 in forum 3D Modelling
    Last Post: 25th Jun 2008, 09:02 pm
