Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Default converting 3D poliline in 2D?
    hi all
    I've searched already online and I just found the command CONVERT, i applied it but my 3d polyline doesn't get converted in 2D..
    any other suggestion?
    basically i need to change the linetype into dashed, and it doesn't let me do it, i think it depends on the fact that it is a 3D polyline
    please advice thank you!
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    I think that the command CONVERT is not appropriate, as it only converts polylines that are 2D to start with.
    If you use the command Flatten, then the 3D polyline will have all vertices at zero elevation, but it is still a 3D polyline, which can only have a Continuous linetype.
    So explode it and use Pedit to re-make the polyline as a 2D polyline, and then you can have any linetype that you want.
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Quote Originally Posted by eldon View Post
    thanks! i have exploded it but then i don't succeed to convert it into a polyline. When I do pedit, and select all the pieces, it starts to get me various options but i never get to an end. i then need to esc, and that's it, i still have
    the exploded opject
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Quote Originally Posted by cat3appr View Post
    the exploded opject
    Zero object joined... it doesn't like to join those small exploded polylines..
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    When I use Pedit, I first of all pick one line, turn that into a polyline and then use the Option Join, and then when it says select objects, I type "all". As long as your polyline segments do not join onto anything else, then the polyline is formed.
    Does the original polyline only consist of straight lines? and did you use the command Flatten?
  6. #6
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    no it doesn't work... i only converted the first segment, then he doesn't want to join the others... better if you try in the actual file attached....
    thans!
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    Can you post the original 3D line please?
  8. #8
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    here's the original, please if you manage, best would be to post the file already formatted. I need it dashed. 2D polyline dashed
    than you!
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    Thank you for responding so quickly and posting the drawing.
    I don't know what I am doing different to you, but using my system, I managed to make it all one 2D polyline.
    First of all I exploded it (it was already at zero elevation). Then starting Pedit, I chose one segment and turned that into a polyline. I continued with the option Join, and typed "all" when asked to choose objects. It joined up 84 segments. I turned on the linetype generation, and made the attached drawing file. I changed the layer name to Red, so that I was not confused (easy for me to do!!)
  10. #10
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    I use a lisp routine to convert 3d polylines to 2d. See attachment below. Just load it and then type PL32 at the command line to run it.
    You can thank Tony Hotchkiss. He wrote it.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  1. How to insert a Block with Attributes linked to a poliline
    By Lui in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Aug 2015, 04:00 am
  2. Poliline flashing
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Oct 2012, 08:10 pm
  3. 3D Poliline specific object dont work
    By infect in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Jan 2012, 07:39 pm
  4. Poliline Lisp
    By jan_ek in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Dec 2010, 10:55 am
  5. Poliline 2D to poliline
    By psyfr3ak in forum AutoCAD Beginners' Area
    Last Post: 22nd Jun 2010, 08:14 pm
