Results 1 to 5 of 5
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Default can't change attributes of a line
    hello
    I have a few annotative lines that i need to edit: the original ones come out directly from a CAD related software, which labels some events along a strip. Then i manually have to edit those events, but when I plot the result here's the situation
    the UTA, and BRS which I edited appears darker than the others, which I didn't edit. this is because for some reasons I can't copy the properties from the original to the one I edited... so I end up with a darker plot... how would you solve this?
    many thanks!
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,592
    Look at the properties of the line one has maybe had the lineweight set to non zero or the bylayer is non zero or the color has a lineweight set to it in the CTB being used.
    Look at your layers Default & 0.0
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    If you go into the Layer Properties Manager, the layer "Events Panel 1 Markers" has the lineweight set to 0.00mm.
    You have drawn your edited marker lines on layer 0. If you wanted all your marker lines to be the same (thick or thin) then you should draw them all on the same layer.
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    of course... didn't think of that, thanks a lot guys!!
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Match Properties fixed here.
    In the future, when I modify something like that I use LAYMCUR (Make objects layer current) so I am on the correct layer when I start modifying.
  1. attributed blocks to change layer of Attributes & color of Attributes=bylayer?
    By chico1201 in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th May 2015, 02:28 am
  2. Change fonts in text style and line thickness in all layer from command line?
    By mdbdesign in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Oct 2011, 03:00 am
  3. couldn't change the line weight of resistors, or change their color
    By jackson6612 in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2011, 12:10 pm
  4. Change attributes
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Apr 2010, 04:33 pm
  5. How Change Line Length Depend On Attribute Value Change
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Apr 2009, 03:08 am
