Results 1 to 7 of 7
    Full Member
    AutoCAD LT 2014
    May 2011
    95
    Default Customize a multileader?
    I have a power symbol for 13amps that I want to use as an arrow, place it on a layout, rotate it to align then have a line leading to the description of that outlet, and a prompt to indicate height that will be added in to the description.
    Right now I can only do it with a static arrow and description, I then have to manually change the description and rotation of the power outlet.
    It would simplify my work flow but Im not entirely sure this is possible... Any ideas?
    AutoCAD 2013
    Nov 2011
    6,051
    When in doubt, check LeeMac out, as I always say.
    Check if any of these might be helpful.
    http://www.lee-mac.com/autoblockbreak.html
    http://www.lee-mac.com/objectalign.html
    http://www.lee-mac.com/dynamicblockcounter.html
    These are just the tip of the iceberg, spend a few minutes looking at all that Lee so generously offers to the global cad community.
    There may well be others which will suit you more than these.
    These are not ones which I personally use, but there are tons which I do, a couple of personal favorites are LAYER DIRECTOR and BATCH FIND & REPLACE TEXT.
    Both of those are absolutely brilliant.
    Thanks Lee!
    I just stumbled across some others that you may like... http://www.lee-mac.com/label.html
    http://www.lee-mac.com/blockcounter.html
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Make a dynamic block might be the easiest.
    Can you post a before and after example?
    Full Member
    AutoCAD LT 2014
    May 2011
    95
    https://imgur.com/04V4CCg
    I played around with it more and found that Block Attributes work for amps, number of switches, height etc. so when I place my multileader, when it's done a prompt comes up instead so this is done.
    I created a dynamic block for the amp sign and used it as an arrow.
    From the picture, you can see I need to explode the Mleader, manually rotate the amp and join the lines. I was hoping to have the amp line up to whichever line its on and the lines to join (both insertion point and center extents dont work).
  5. #5
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    Do you want it to all be one entity or do you want the leader to actually be a leader? It is possible to do either.
  6. #6
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    I cant see images from third party hosting sites. Can you post directly to CADTutor?
  7. #7
    Full Member
    AutoCAD LT 2014
    May 2011
    95
    I cant seem to load cadtutor's image uploading popup.
    Anyway, I just want to be able to rotate the switch symbol then have it attached to the description. I already have the description set up with attributes so now i'm just figuring how to make it rotate and the lines to connect.
  1. Customize Lee Mac's LM:writecsv
    By Draugnim in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Oct 2016, 06:14 pm
  2. Customize LT 2009
    By Susan-Skye in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Oct 2010, 11:46 am
  3. Customize Fields
    By KnoJa31 in forum AutoCAD General
    Last Post: 9th Apr 2010, 09:56 am
  4. Cannot customize toolbar
    By manyee in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Aug 2008, 08:43 pm
  5. Customize Components
    By Kari in forum Revit General
    Last Post: 28th May 2008, 10:08 am
