Problems with sum of List
EricDevault
I have a 'while' loop that adds what was entered in the command line to a list each time it loops. Then I would like to get the sum of all the numbers in the list. I am pretty confident that this should work:
(setq CLength1 (apply '+ (list lst)))
But I get this error on the command line:
; error: bad argument type: numberp: (36 36 36 36)
Full 'while' code:
(while
(initget "U")
(setq d (getdist (strcat "\Distance to next Vert Strap (Enter when done; U to Undo)"))))
(setq lst (cons (fix d) lst))
(cond
((= d "U") (command "._undo" "._back"))
((/= d 0)
     (command "._offset"
              (/ d 12.)
              s
              "_non"
              (polar (cdr (assoc 10 (entget s))) 0. 1.)
     (if (not (eq s (setq s (entlast))))
         (setq p1 (cdr (assoc 10 (entget s)))
               p2 (cdr (assoc 11 (entget s)))
               pt (if (< (cadr p1) (cadr p2))
                    p1
                    p2
	  (setq dx1 (car p1)   ;ent x value
			dx2 (cadr p1)  ;ent y value
			dx3 (caddr p1) ;ent z value
			dd1 (+ dx1 (/ d 12)) ;dimension distance
			sdx (- dx1 (/ d 12))  ;start point x
			dmx (/ (+ dd1 dx1) 2) ;middle
	  (if (>= d 18)
	(setq doff -1.6)
	(setq doff -3.2)
         (entmake (list (cons 0 "DIMENSION")
	  (cons 100  "AcDbEntity")
	  (cons 67 0)
      (cons 8  "DIMBAD")
      (cons 100  "AcDbDimension")
	  (cons 10 (trans (list dd1 doff 0.) 1 0))
	  (cons 11 (trans (list dmx doff 0.) 1 0))
	  (cons 12 (list 0. 0. 0.))
	  (cons 70  33)
      (cons 1  "")
      (cons 71  5)
      (cons 72  1)
      (cons 41  1.0)
	  (cons 52 0)
      (cons 53 0)
      (cons 54  0)
	  (cons 3  "TEMPLATE_DRAWING")
	  (cons 100  "AcDbAlignedDimension")
	  (cons 13 (trans (list sdx 0. 0.) 1 0))
	  (cons 14 (trans (list dx1 0. 0.) 1 0))
	  (cons 15 (list 0. 0. 0.))
      (cons 16 (list 0. 0. 0.))
(princ CLength1)
Try it
(setq CLength1 (apply '+ lst))
Whole Code :
(while
   (initget "U")
   (setq d
   (getdist
     (strcat
  (cond
    ((/= d 0)
(command "._offset"
	 (/ d 12.)
	 s
	 "_non"
	       p1
	       p2
    (if	(>= d 18)
      (setq doff -1.6)
      (setq doff -3.2)
		   (cons 67 0)
		   (cons 8 "DIMBAD")
		   (cons 70 33)
		   (cons 1 "")
		   (cons 71 5)
		   (cons 72 1)
		   (cons 41 1.0)
		   (cons 52 0)
		   (cons 53 0)
		   (cons 54 0)
(princ (rtos lst 2 0)) ; Add precision here
Try it
Whole Code :
(while
   (initget "U")
   (setq d
   (getdist
     (strcat
  (cond
    ((/= d 0)
(command "._offset"
	 (/ d 12.)
	 s
	 "_non"
	       p1
	       p2
    (if	(>= d 18)
      (setq doff -1.6)
      (setq doff -3.2)
		   (cons 67 0)
		   (cons 8 "DIMBAD")
		   (cons 70 33)
		   (cons 1 "")
		   (cons 71 5)
		   (cons 72 1)
		   (cons 41 1.0)
		   (cons 52 0)
		   (cons 53 0)
		   (cons 54 0)
Yup, that's it! Every example saw said to call out the list as (list lst) not sure why. But anyway thank you
When you are adding (setq lst (cons (fix d) lst)) at that time itself you are defining lst variable as list already then no need to add (list lst) again.
Instead of constructing the list, you could perform the summation directly - e.g. replace:
With:
(setq CLength1 (+ (cond (CLength1) (0)) (fix d)))
