Results 1 to 8 of 8
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    Default PUBLISH Progress Window
    I use the PUBLISH command on a daily basis. As each job gets published to PDF I examine the small icon in the lower right side of the AutoCAD window for how it's coming along. Not the easiest way to monitor a job but it works. Now a co-worker was publishing a set of PDF's and his setup included a large window which showed which drawing was being published, and it had two progress meters in it to show progress on the current file and progress on the entire job. When I asked him how he set that up he said he had no clue and that his system always does that. Since we're running the same version of AutoCAD I can conclude that my system is capable of the same thing.
    It's deja vu, all over again.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,768
    I think it is whether or not you are publishing in the background, at least from my experience.
    I haven't published in the background for some time because my work system is pretty fast and most of the jobs are small. The disadvantage of publishing in the foreground (default) is that autoCad is locked up for the duration, so all you can do is watch the green bars. However. the green bars are way big and right up front where you can see them, which is good, because you will be inexorably compelled to stare at them.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    Not sure how complex your dwgs are but I just plot using a lisp and it changes layouts as it goes and I just watch it makes each pdf say 2-3 seconds ? Yeah I do have 88 layouts in one dwg and the only hassle is that the pdfs are displayed via acrobat and it stops displaying after about 15 but the whole 88 plot. Never been any real delay.
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    The jobs consists of about 5 to 10 CAD files, each contains anywhere from 2 to 10 layout tabs. I always publish in the background. This computer is an I7 with 32 GB RAM. So it's no slouch but still sometimes with these huge XREF's there is a delay. What I don't see is this nice window which shows which drawing is being published and the progress meters showing how far we've got to go. All I can do at the moment is to hover the mouse over the little Publishing icon in the lower right corner and it will tell me 13 of 18, but nothing more.
  5. #5
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,768
    Quote Originally Posted by Bill Tillman View Post
    That is what publishing in the background is. It assumes you don't want to wait for it so you can continue working while it publishes. Also, running anything in the background waits for the system to give it run time. It then competes with everything else that is running. The more cadding you do, the less computer run time there is available. Active open windows (apps) get the highest priority, so basically you can get in your own way. Publishing in the foreground gets top priority computer time.
  6. #6
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    Thanks Dana, I finally found the checkbox which disables/enables publishing in the background. It's the one that says, "Publish in background"....doh! and it's right there in the publish dialog window. If I had not been looking so hard for it, I probably would have found it sooner. So now that I know it's there I can use when I need to. Most of the time I publish in the background because with this client every project they give me is already 3 weeks past due. Doh!
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    Yeah that is pushing multiple drawings, xrefs etc we only have to worry about 1 dwg. Makes sense use publish to create a set.
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,768
    That's ok, I spent about half an hour looking for the TV remote this morning with it in my hand.
  1. PUBLISH and Lisp / BlackBox's PUBLISH Reactor
    By Grrr in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jun 2016, 07:47 am
  2. Progress bar
    By Sweety in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Jul 2013, 12:35 pm
  3. Publish Window Popup
    By resullins in forum AutoCAD General
    Last Post: 28th Jun 2013, 04:21 pm
  4. In progress
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 11th Dec 2008, 04:02 pm
  5. Publish Job Progress Dialog Box
    By plumeg in forum AutoCAD Drawing Management & Output
    Last Post: 30th Aug 2006, 11:43 pm
