Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Default Layers draw order ; first last
    hi
    I have several drawings based on hatches and some lines.
    I always want the hatch layer to appear last, in the very background, then line 1 second last, line 2 3rd last, and so on... based on layer ( i think)
    is there a way to set and lock the priority of layers, in this manner?
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    This may help and does not use draw order, assign an elevation to each layer in the order required I have found this to work as a simple method.
    I have something I do all the time and it has 4 draworders but I just know the order to make it work.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,312
    I just did a quick search and found the lisp routine below. Just edit the code to set your layer order as you want it, then load and run the routine.
    Code:
    ;;; OrderByLayer.lsp
    ;;; By 3wood 2015.12.24
    ;;; Change the layer name and add more layers to suit.
    ;;; The first layer will be sent to front and the last layer sent to back.
    (defun C:OrderByLayer ()
      (command "._DRAWORDER" (ssget "_A" '((8 . "Layer1"))) "" "_B")
      (command "._DRAWORDER" (ssget "_A" '((8 . "Layer2"))) "" "_B")
      (command "._DRAWORDER" (ssget "_A" '((8 . "Layer3"))) "" "_B")
      (command "._DRAWORDER" (ssget "_A" '((8 . "Layer4"))) "" "_B")
      (command "._DRAWORDER" (ssget "_A" '((8 . "Layer5"))) "" "_B")
      (command "._DRAWORDER" (ssget "_A" '((8 . "Layer6"))) "" "_B")
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Quote Originally Posted by Cad64 View Post
    Code:
    thanks Cad64, so how to use it... i only understand that i should replace " Layer1" with my named layer, but what is ssget"_A" and ((8. ? what do i do with A and 8? is it possible to have an example with 2 layers?
  5. #5
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Quote Originally Posted by BIGAL View Post
    I went to layer property of the hatch and assigned elevation -1 . all the other layer's properties have elevation 0, so this should keep that hatch layer always behind, correct?
    But after saving the DWG and re opening it, the hatch wasn't in the back ... so i guess something is not right
  6. #6
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    ok i've attached the drawing i'm working on.
    If you open the layers, HATCH layer should always be in the back, and is not, even after assigning a negative elevation.
    Layers: Overage and Overage+5 should be on top layer Hatch but below AS-Laid Pipeline Line...
    How to do this in an automatic way?
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,094
    Opens correctly here in AutoCAD 2018, I tried in AutoCAD 2011, but it said drawing was created in newer version, I converted it back to 2010 and got that it had 8 errors and needed recovered, it then opened correctly in AutoCAD 2011. What Version of AutoCAD are you using?
    Could it be your graphics card or driver?
    Error when opening.
  8. #8
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,312
    Quote Originally Posted by cat3appr View Post
    The only things you have to edit in the code are the layer names. Everything else stays the same. You said you want your hatch layer at the very back, so that layer name should be at the bottom of the list, then arrange your other layers in the order you want them to display above the hatch layer. See below.
    Code:
    (command "._DRAWORDER" (ssget "_A" '((8 . "Top_Layer"))) "" "_B")
    (command "._DRAWORDER" (ssget "_A" '((8 . "Middle_Layer"))) "" "_B")
    (command "._DRAWORDER" (ssget "_A" '((8 . "Hatch_Layer"))) "" "_B")
    Facebook:
  9. #9
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Quote Originally Posted by SLW210 View Post
    Error when opening.
    Thanks SLW, I use CAD MAP 2015, what sort of mistakes did you get?
    Graphic card is fine, it's fine, it can be anything else then.. windows, heating system etc.. I just need to organize some layers, if it can be easily done, ok, or else i just leave them as they are
  10. #10
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,094
    Displays in correct order here in AutoCAD. Maybe it's a MAP issue. You need to update your profile or include what you are using in your question.
  1. Alter draw order of selection set on different layers
    By cletero in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Aug 2014, 08:17 pm
  2. Draw Order
    By Squirltech in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 13th Oct 2010, 06:27 pm
  3. Draw Order?
    By criehle in forum AutoCAD Beginners' Area
    Last Post: 17th Mar 2009, 08:16 am
  4. Draw Order
    By lenback in forum AutoCAD General
    Last Post: 21st Nov 2008, 02:35 pm
  5. Draw order
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 3rd Aug 2007, 09:21 pm
