Results 1 to 4 of 4
    Forum Newbie
    Electro/Mech
    AutoCAD 2017
    Feb 2018
    3
    Default Extracting and Adding Dim Info
    Hello All,
    I am working on making Bills of Materials with Block information. I use tubing as a main component in my data extractions. What I would like to do is be able to extract the text overwritten length that I dictate from the all dimension leaders with the same part number, and add them to get an overall length of tubing used in the assembly.
    For instance if I have two blocks, both with the part number "tube 1" but one has a dimension leader where I overwrite 5 (inches) and one has a dimension leader where I overwrite 6 I would like the data extraction to show "tube 1" with 11 (inches).
    Much appreciated!
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,589
    Sounds simple for the best help post a dwg with a couple of blocks.
    Forum Newbie
    Electro/Mech
    AutoCAD 2017
    Feb 2018
    3
    Hello,
    I would like the QTY of SIL-C-0250-2 to read 19.0 and the QTY of SIL-C-0625-4 to read 12.0 even though the measured distances aren't equal to the overwritten distances.
    Forum Newbie
    Electro/Mech
    AutoCAD 2017
    Feb 2018
    3
    My mistake, I have added the image now.
    Thanks!
  1. Extracting Object info
    By richsullivan in forum AutoCAD General
    Last Post: 3rd Mar 2016, 03:04 pm
  2. Adding info from google maps
    By Kevan321 in forum AutoCAD General
    Last Post: 7th Aug 2012, 01:45 pm
  3. Extracting block info
    By Diast in forum AutoCAD Beginners' Area
    Last Post: 1st Jun 2010, 07:45 pm
  4. Adding info to the plot log cvs file?
    By Ace in forum AutoCAD General
    Last Post: 29th Apr 2010, 09:27 pm
  5. Extracting attribute info without opening the drawings
    By Wozza in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Feb 2005, 08:14 am
Tags for this Thread
