Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    My thought is that you are trying to get AutoCAD to use a point on the curved surface of the cyan colored solid to create your dimension. AutoCAD doesn't appear to recognize what you are attempting to pick and instead picks the nearest true geometry it can distinguish.
  2. #12
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Use some construction geometry - in this case a Section - then snap from Quad to Quad.STUB 1 SA1-SC7 45°_Sect.dwg
  3. #13
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    all right i understand, i thought that autocad dimension like if i use the flatten command
  4. #14
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    Quote Originally Posted by SEANT View Post
    Use some construction geometry - in this case a Section - then snap from Quad to Quad.Attachment 63422
    if i in your file i use 3dorbit or orbit all the drawing disappear.
    ok i recover the dwg, but how did you dimension?
  5. #15
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    all right i have already of default quadrant but now i see to set ucs as current view i able to dimension that segment , however thanks a lot for you time to give me,.
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I'm not 100% sure that is exactly what the OP wants to dimension. Could be wrong though.
  7. #17
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    Yes i start this post to know if it was the right method to dimensioni with 3d model .thanks
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I don't think you know what I was referring to. Go back and look at SEANT"s drawing. Did he in fact dimension the 3D model where you wanted it or not? Yes/No?
  9. #19
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    ok i look the seant's model.yes the dimension is correct
  1. creating a layout w/ dimension from a 3D model
    By Ninoshka in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Jun 2014, 07:30 pm
  2. Metric dimension inputs in an imperial model
    By keatzz in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Feb 2013, 06:40 pm
  3. How to setup Model Space Dimension Text Height then make it annotative
    By JamFam in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Aug 2010, 11:20 pm
  4. Replies: 10
    Last Post: 16th Oct 2007, 12:41 am
  5. how do i put a dimension in a 3d model
    By free2fly in forum AutoCAD General
    Last Post: 5th Jan 2006, 06:11 pm
