Results 1 to 6 of 6
    Full Member
    AutoCAD LT 2014
    May 2011
    95
    Default How do you make everything inside a viewport transparent?
    I want to mark some dimensions etc. in the layout panel directly on top of the viewport but i also want them to stand out. However, I only want them to be transparent in 1 layout.
    Currently, I copied the objects, made a new layout for it, went back to modelspace and changed their transparency then print.
    Surely it is possible to just select the viewport, make everything it displays to be transparent while leaving everything else in the layout tab. This would be such an easier method.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    Are you still using Autocad 2010? You should upgrade to the latest version so you can set layer transparency within the viewport.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    697
    Yes, It is a very welcome new layeroptions that was introduced some years ago..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Full Member
    AutoCAD LT 2014
    May 2011
    95
    using 2014 LT
    i tried layer transparency, i put the viewport on its own layer and set it to 95. But only the viewport is transparent, the contents in it are not.
  5. #5
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    Setting the viewport to transparent is not correct. You need to double click inside the viewport, then open your properties palette and set the "VP Transparency" for each layer that you want to have transparent.
    If you're not seeing the transparency effect on screen, you may need to enable it. Type TRANSPARENCYDISPLAY at the command line and change the setting to 1. https://knowledge.autodesk.com/suppo...A0D0C-htm.html
    Also, you should update your profile information to show that you are using Autocad 2014 LT. Right now it says Autocad 2010.
    Facebook:
  6. #6
    Full Member
    AutoCAD LT 2014
    May 2011
    95
    oh i have to do it for every layer? guess i was doing it wrong, i thought it was a simple case of setting the viewport to 95 transparency.
    updated profile.
  1. How do I make a transparent material?
    By Unmentioned in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Dec 2009, 02:17 pm
  2. Way to make text visible inside paperspace viewport?
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2006, 08:30 pm
  3. How to make window transparent?
    By nisman in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Sep 2006, 10:40 pm
  4. Is it possible to make viewports transparent on printing
    By ALEX3020 in forum AutoCAD Beginners' Area
    Last Post: 18th Oct 2005, 05:37 am
  5. Can you make a viewport non-transparent?
    By matrix in forum AutoCAD General
    Last Post: 19th Jun 2003, 10:44 pm
