Results 1 to 5 of 5
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Default Trim inside a box on multiple blocks
    Hello,
    I have this map panel made by several blocks imported and constructed in CAD with an external utility.
    The KP box looks terrible when other blocks go through it, but I can't trim inside because the KP box is on the main DWG , while the other bjects that I'd like to trim are part of other blocks.
    Starting from the point that I can't alter the blocks - the DWG has to remain like this, with blocks. Is there a way to trim inside that KP box?
    many thanks!
    Alex
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,606
    Have you looked at Wipeout ?
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Quote Originally Posted by BIGAL View Post
    wow fantastic! thanks!
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    basically first you moved the KP number outside, ( i need to keep the 1. wiped out and placed the KP back right?
  5. #5
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    814
    Quote Originally Posted by cat3appr View Post
    Wipeout doesn't actually erase anything. After adding it simply select the KP number or anything you want visible and bring it to front with draworder.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  1. Explode Blocks Then Trim Rectangle & Circle Inside Area
    By sanju2323 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Aug 2015, 02:55 pm
  2. Trim Lines Even If Line Is Inside A Block
    By kArThIcK hAcKeR in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Aug 2014, 09:12 am
  3. Trim objects outside or inside of polyline object/s
    By notview in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Sep 2013, 01:14 pm
  4. Trim inside circle
    By goonkt in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2012, 06:28 am
  5. Trim inside circle
    By Cube3 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Sep 2007, 07:26 am
