Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Forum Newbie Vittorio's Avatar
    Vittorio's Computer Details
    Windows 7 Pro 64-bit SP1
    MSI MS-7502
    Intel Core 2 Quad Q6600 @ 2.40GHz
    8.00GB GEiL Dual-Channel DDR2 @ 332MHz (5-5-5-15)
    896MB NVIDIA GeForce GTX 260 (EVGA)
    Samsung SSD 850 EVO 250GB
    Western Digital WDC WD10EADS 1000GB
    iiyama ProLite XB2374HDS
    Surveying
    Vittorio's Discipline Details
    geodesist
    Surveying
    AutoCAD 2018
    Mar 2018
    Germany
    8
    Default LISP - select objects of specific type
    Hello Everybody, this is my first post and I'd like to know a little bit more about the ssget command.
    I already searched the world wide web for various search keywords, but couldn't find references / lists, especially of the Associative codes and object types.
    I also read a lot of articles about that command, but most of them use these Associative codes:
    http://www.lee-mac.com/ssget.html
    https://knowledge.autodesk.com/searc...3B2C3-htm.html
    http://www.afralisp.net/autolisp/tut...ction-sets.php
    They
    Since I am a total newbie with AutoLISP please explain things easily.
    What I would like to do in the first place is selecting objects via LISP, since there seems to be no command line version of SELECT, QSELECT etc.
    and therefore I need:
    • a list of "names" of object types that exist in AutoLISP (eg. TEXT, LINE, etc)
    • all neccessary parameters for the ssget function
    Let's say I want to select a table in a drawing, how can this be done?
    What if there are more than one tables?
    Many thanks in advance
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Welcome to CADTutor Vittorio.
    If you have already studied the documentation for the ssget function as found on my site, or in the Autodesk documentation, then you should already be familiar with the parameters which may be supplied to the function: the mode string argument to determine the type of selection, the point & point list arguments when specifying a selection window/polygon, and the filter list argument to filter the properties of objects which may be selected.
    Since your question is predominantly asking about the filter list argument and the various entity types which may be filtered, I would first suggest that you refer to a DXF Reference.
    To understand the entity types available, refer to the ENTITIES section of the reference.
    For example, for a Table, the DXF reference shows that the entity type (DXF group 0) is "ACAD_TABLE". Therefore, to obtain a selection of all tables in the drawing, you might use:
    Code:
    (ssget "_X" '((0 . "ACAD_TABLE")))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    MSI MS-7502
    Surveying
    geodesist
    Surveying
    AutoCAD 2018
    Mar 2018
    Germany
    8
    Quote Originally Posted by Lee Mac View Post
    Code:
    I did, but nothing happened. Here's a copy of the ACAD Text Window:
    Code:
    Command: APPLOAD
    selectTable.lsp successfully loaded.
    Command: SELECTTABLE
    <Selection set: 18867>
    <Selection set: 1888d>
    <Selection set: 1888f>
    Command: (ssget "_X" '((0 . "ACAD_TABLE")))
    <Selection set: 188ca>
    <Selection set: 188d4>
    here is the LISP selectTable.lsp
    Code:
    (defun c:selectTable nil
      (vl-load-com)
    As I already said, I'm a total noob in AutoLISP.
    So here is what I am understanding:
    The ssget syntax as described on your site or at Autodesk Help:
    (ssget [mode-string] [pt1 [pt2]] [pt-list] [filter-list])
    ssget - required
    [mode-string] - "_X" (Extended Search - Entire Drawing Database)
    [pt1 [pt2]] - "" (Point 1, Point 2, ...) => empty: no points selected
    [pt-list] - "" (Point List) => empty: no point list
    [filter-list] - here we go... I just don't get this part
    • Why is the whole thing eclosed in double parentheses?
    • Why is there an apostroph before the first parenthesis?
    • Why is there a dot between the group code and the entity name?
    • What exactly does the "0" stand for? Group Code? There are many 0s in the reference.
    • Is the "0" bound to the entity name? If so, why is there no "0" or entity name for the LINE object?
    Here is a part of the Reference:
    Table group codes:
    Group code / Description
    0 / Entity name (ACAD_TABLE)
    Line group codes:
    100 / Subclass marker (AcDbLine)
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    A couple more hints you can filter more than one type of entity in one go
    Code:
    (ssget "_X" '((0 . "Line,Lwpolyline"))) finds lines and poly lines
    (ssget "_X" '((0 . "Text,Mtext")))  finds text and mtext
    (ssget "_X" '((0 . "*Text")))  finds text and mtext
    (ssget "_X" '((0 . "Insert"))) one that is not obvious this finds blocks.
    (ssget "_X" '((0 . "*Text")(8 . "123")))  finds text on layer 123
  5. #5
    MSI MS-7502
    Surveying
    geodesist
    Surveying
    AutoCAD 2018
    Mar 2018
    Germany
    8
    I tried and pasted the code into command line, but all that AutoCAD tells me is: "<Selection set: XY>" with XY being an incremented number / letter
    There is nothing selected after applying (ssget "_X" '((0 . "Line,Lwpolyline"))) for example...
    How can I actually select objects in AutoLISP?
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    At its most simplest (setq SS (ssget)) you then have a selection set of objects. Note the SS this the variable name that is holding our selection of objects. All the above are examples of ssget but we all forgot to save the selection to a variable. In saying that there are situations where you dont need to assign to a variable. Like move copy erase etc.
  7. #7
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    295
    If i understand the question...
    SSGET create a selection SET
    If you want to actualy SELECT them.. your looking for the sssetfirst function.
    Have a look at this:
    https://knowledge.autodesk.com/searc...0D2D8-htm.html
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    Again you need to explain what is it your trying to do, ignore the ssget for the moment do you want to pick objects and do something with them ? Explain what it is you want to do.
    Code:
    an example
    (command "Erase" (ssget "X" '((8 . "0"))) "") erase objects on layer "0"
    Code:
    (setq ss (ssget "X" '((0 . "TEXT"))))
    (setq obj (ssname ss x))
    ... do stuff here like
    .... get insertion point
    (setq x (+ x 1))
  9. #9
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,013
    maybe OP just want to use the select command in combo with ssget?
    Code:
     (command "select" ss)
    But I agree he has to give more info in what he is trying to do...
    gr. Rlx
  10. #10
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    859
    You might also study THIS.
  1. Lisp needed for Move objects with specific distance
    By dreams in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Feb 2017, 02:39 pm
  2. Lisp to select all objects on specified layers
    By PianoMan in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jan 2016, 12:41 am
  3. Lisp to select and hatch objects
    By pixel8er in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Aug 2011, 05:09 pm
  4. how to select all visible objects by lisp ?
    By ahyin in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Aug 2010, 07:42 am
  5. how to filter select objects by 2 type of layer in single set
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Dec 2009, 01:23 pm
Tags for this Thread
