Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    814
    Quote Originally Posted by Cad64 View Post
    What is the reason for so many drawings open? As you mentioned, having too many files open does affect performance. Perhaps the answer is simply to streamline your workflow and only open the drawings that you really need. Others can be opened and closed as necessary.
    Besides the performance boost this automatically arranges all the previously opened drawings organized starting the latest on opened on top the way cat3appr wants. With the Application Menu Number of recently-used files set to 50 you can quickly scroll through to open them.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  2. #12
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,207
    Quote Originally Posted by cat3appr View Post
    yes it vital for me to have many DWG opened. This is also slowing down CAD drastically as it sucks lots of RAM
    Is it not possible to xref several dwgs into one? If you make minor edits in them, you can use the edit in place option.
    breaking AutoCAD on a regular basis since 1991
  3. #13
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    Any chance you have access to a later version? I know AutoCAD 2018 can rearrange the Tabs by simply Click+Hold and dragging them.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  4. #14
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,589
    Are you stealing stuff from other dwgs, just demand open then close use palettes for the dwgs or think seriously about block libraries.
    lee-mac has steal.lsp that allows you get stuff from a dwg without opening.
  5. #15
    AutoCAD 2013
    Nov 2011
    6,051
    How about turning on the Quick View Drawings option, in the Application Status Bar menu, in the lower right hand corner of your screen?
  6. #16
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    814
    Quote Originally Posted by Dadgad View Post
    In newer versions QVD opens Quick View Drawings and QVL opens Quick View Layouts, but they're no longer on the Status Bar. Guess they figured Drawing Tabs was good enough.
    You can also hover over the icon in the Windows Taskbar to see and select any open drawing and you can do the same for layout tabs so it's probably not really that big a deal.
  1. Replies: 2
    Last Post: 5th Jan 2016, 04:29 am
  2. Can AutoCAD 2015 be used with Visual Studio 2015?
    By muck in forum .NET, ObjectARX & VBA
    Last Post: 22nd Feb 2015, 07:56 pm
  3. Importing an Autocad 2015 3D dwg file into Inventor 2015
    By dalzielcad in forum Autodesk Inventor
    Last Post: 30th Jan 2015, 07:42 pm
  4. Page tabs for 2015
    By Efeezy in forum AutoCAD Beginners' Area
    Last Post: 14th Jul 2014, 09:12 pm
  5. New Layout Tabs features in AutoCAD 2015
    By Lynn Allen's Blog in forum AutoCAD RSS Feeds
    Last Post: 12th May 2014, 04:50 pm
