+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Forum Newbie
    Using
    Revit 2017
    Join Date
    Mar 2018
    Posts
    4
    Default Can I 3D model in detailed insulation ( link ) to avoid thermal bridging ?
    Hi, am learning basic drawing skills on Revit (Lynda.com) , as I want to experiment with Rivet's analytical / simulation tools.
    However I wonder if it's possible to 3D model in details like insulating cellulose bricks, special balcony connections and much more that are used to avoid thermal bridging..
    Because if that's impossible, Revit's thermal analysis tools would be totally useless for me.
    Used Autocad in college way back, now want to learn Revit to try and simulate / analyse a passive single family house
    cheers
  2. #2
    Luminous Being tzframpton's Avatar
    Computer Details
    tzframpton's Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    tzframpton's Discipline Details
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Using
    Revit 2019
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,115
    Default
    Yes, you can do that in Revit. But I may be misreading your question. Do you mean an analytical calculation? Walls do have thermal properties, but not sure how that would work if a very small strip of a wall needed to have it's own thermal properties. If that's the case you would simply use two walls with proper cuts and joins.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  3. #3
    Forum Newbie
    Using
    Revit 2017
    Join Date
    Mar 2018
    Posts
    4
    Default
    I get the impression it's all very conceptual in Revit ... Not really accounting for details and so on
  4. #4
    Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2019
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,115
    Default
    Were you expecting the platform to be fully capable in certain specific areas? The program is first a parametric modeling application for architectural design. Things like calculation of thermal properties would be down the line. Sounds like it will be too general for your needs so the thermal calc tools will not suffice.
    Also try asking the question in a forum that has a much larger Revit user base. I'm an MEP background, this is better asked for the guys and gals who actually have to account for this day in day out. Try the Autodesk forums or others, you may get better answers.
    -TZ
  5. #5
    Forum Newbie
    Using
    Revit 2017
    Join Date
    Mar 2018
    Posts
    4
    Default
    Cheers I will
    was very helpfull here anyway though !
Similar Threads
  1. Seeking a CAD drawing of a thermal fluid heater.
    By ReMark in forum AutoCAD Drawing Management & Output
    Last Post: 6th Mar 2014, 12:14 am
  2. thermal insulation
    By bartymic in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Nov 2013, 04:39 pm
  3. Bridging
    By wileyone in forum AutoCAD General
    Last Post: 15th Jun 2012, 04:48 pm
  4. Thermal insulation hatch
    By Demtor in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 27th Nov 2011, 04:49 pm
  5. Link constraints sending my model parts haywire!!
    By cameroon95 in forum Rigging & Animation
    Last Post: 27th Oct 2008, 11:46 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
