Results 1 to 2 of 2
    Forum Newbie
    Surveying
    AutoCAD 2002
    Mar 2018
    1
    Default import data from xml file to autocad custom properties and export to word
    I need some lisp or vba app so that i can fill in autocad custom properties values from an xml file and export to word. Thanks
    3001.xml.txt
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,597
    A couple of suggestions you need to learn about programming in general and in particular how to read a text file line by line. Look at what is on that line and do something. open the file with notepad and you can read it.
    2nd is do all the code in word which has VBA built in as its macro language.
    3rd is I any one else has no clue what it is your trying to extract from the file.
  1. Replies: 10
    Last Post: 22nd May 2014, 10:34 am
  2. Need help on export and import shape file in AutoCad 2012
    By sarabharaju in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2014, 12:17 pm
  3. how can i import data from xml file to autocad custom properties?
    By ChirilaDan in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jun 2013, 07:05 am
  4. Is it possible to import csv. file data into AutoCAD?
    By Treehugger in forum AutoCAD General
    Last Post: 23rd Jan 2013, 02:59 am
  5. Import data from more AutoCAD file without opening
    By wrha in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Nov 2011, 04:33 pm
