Results 1 to 9 of 9
    Super Member wimal's Avatar
    Construction
    wimal's Discipline Details
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    517
    Default Remove unreferenced files from the external reference dialog box
    How can remove this unreferenced files from the external reference dialog box.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,152
    Try -PURGE or WBLOCK.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,604
    There are several suggestions here.
    You might also switch to the TREE listing of the xrefs to see if any of those are nested.
    R.K. McSwain
    CAD Panacea | twitter
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    517
    Thanks for the both of you.
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,796
    Select the top one, shift select the bottom one to select the rest, right click inside the selected list, click detach, wait about 3 seconds, done.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  6. #6
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,152
    Quote Originally Posted by Dana W View Post
    Have you tried that? The xrefs in the OP shows orphaned images and the detach option will be grayed out. At least it always has when I've run across them.
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,796
    Quote Originally Posted by SLW210 View Post
    Not sure what you mean by showing orphaned images. Are you referring to "unreferenced"? I don't see anything different in the OP's list from what i see in my list. All's I know is, once I erase a bunch of attached pdf's from modelspace, I go into the XREF dialog and detach them in a group by either shift+select or ctrl+select. They go away in a bunch. Works every time. One can also do the select, punch the icon in the yellow box, click detach, and they go away too. This is in versions 2016, 2017, and 2018.
  8. #8
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,152
    If you have never ran across the issue you wouldn't understand. Looking at the paths to the right of the screen grab, if those are paths only on someone else's computer, Detach has always been grayed out. If you will look to the left of the screen grab, you will see all of the unreferenced files were images. Have a look at rkmcswain's link, you will see this problem has been around a while.
  9. #9
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,796
    Oh, ok. That issue. That is most likely the OP's issue. Looking at that list, I couldn't really tell at first, but looking again, they don't look local at all.
    It has been a number of years since I have had it happen to me. 1099'ing for the mouse ears, xref's were a nightmare in one particular project.
  1. external reference help
    By sandeep410 in forum SolidWorks
    Last Post: 18th Oct 2010, 08:30 pm
  2. Cannot Remove Unreferenced Images
    By geocad in forum AutoCAD General
    Last Post: 24th Aug 2010, 08:42 pm
  3. Layers and external reference files
    By Nardino in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Jun 2010, 03:18 pm
  4. Delete Unreferenced Xref Files
    By MR MAN in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th May 2009, 07:03 am
