Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2002
    Nov 2006
    Brisbane, Australia
    2
    Idea Cannot copy and paste between drawings
    Hey guys,
    I'm using Autocad 2002.
    I am having trouble copying out of a drawing (model space) which i received from someone else, and pasting into my own. The properties on the original dwg file suggest it was created Sept 2001. It appears to copy OK (copyclip/copybase), but when i jump into my file and try to paste, the command line just reads:
    _pasteclip
    and nothing appears in my model space.
    I've tried zooming extents, exploding the original, changing layers and line types etc into the same as in my own dwg. I've also tried to convert/save the dwg file into dxf's and other version dwg's....without success.
    I have about half a dozen drawings received from the same source, and they all let you copy data into them, but won't let you copy/cut out.
    This has had me stumped all day...i've never come across anything like this before.
    Any help appreciated...
    Regards,
    Scott
    Full Member Gary_W's Avatar
    Gary_W's Computer Details
    Win7 Home Premium - 64 Bit
    HP Pavillion Elite
    Intel quad core i5 650@3.20GHz
    6 Gig
    1Gb NVIDIA GeForce GT 320
    WDC 1Tb
    Seagate 1Tb
    Viewsonic VA2213w 22"
    Architectural
    Gary_W's Discipline Details
    Construction (Architectural Design)
    Architectural
    New Builds, Extension, Conversions & Alterations
    AutoCAD LT 2012
    Oct 2006
    North East U.K.
    66
    Default Copy n Paste...
    Hello Scott,
    The layer you are pasting into is not turned off is it?
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,125
    not an answer to your imediate problem but what happens if you insert your supplied drawing into one of your own?
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
    Forum Newbie
    AutoCAD 2004
    Nov 2006
    7
    hi friend
    for copying the drawing from another file ,you can open it and
    right-click on the sheet of which drawing you had to copy and then select the drawing.then right-click on the drawing,open your file and then paste.then put it wherever you want
  5. #5
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,489
    Have you tried to WBLOCK out the entities you need and then insert them into your other drawing as a block with the INSERT command?
  6. #6
    Senior Member
    Architectural DT 2007
    Aug 2006
    Midwest
    218
    If the layers that you are trying to copy is locked, it won't let you copy. Check that first. Second, if you are copying something from model space into paperspace, the object may be too large and will not immediately appear on the screen. In this care, try a zoom extents command, and you should be able to find your object. The next thing to check if neither one of these is the case, try a copy with base point (it's in the pull down 'edit' menu, or Ctrl + Shift + C) and select the base point in the middle of the object, then paste it into your new drawing.
    Let me know if that works for you, or not, I've got other suggestions.
  7. #7
    Junior Member AccessStudent's Avatar
    AutoCAD LT 2008
    Nov 2006
    Arkansas
    20
    Also check to see if the layer(s) of the objects you are copying from exists in the new drawing. If the layers do not exist on the new drawing, they will be copied to your drawing, but you will not be able to see them. (Just Learned in My Intermediate Cad Class)..
    Just a Thought...
    Jeff
  8. #8
    Forum Newbie
    AutoCAD 2002
    Nov 2006
    Brisbane, Australia
    2
    Quote Originally Posted by Gary_W View Post
    Hello Scott,
    Yep i checked this and nothing was frozen/turned off etc. I had identical layers in source and destination files.
    Quote Originally Posted by dbroada View Post
    Bingo!
    For some reason, i thought i had already tried to insert drawing as a block. So i did this, and no problems. Straight into my drawing! Thanks! I feel a tad silly now... Still a mystery as to why i can't copy.
    Quote Originally Posted by autoCAD_dhruv View Post
    hi friend
    Yep, that's what i was already doing. Thanks anyway...i have now resolved my problem with a workaround.
    Quote Originally Posted by Cad64 View Post
    I tried this, and it won't write blocks for individual items. I now have overcome my problem just by inserting block (the entire original source file). Simple as that!
    Quote Originally Posted by pennylove View Post
    I tried all of this with no success. I now found a solution. Thanks anyway.
    PS. i was copying from model space to model space
    Quote Originally Posted by AccessStudent View Post
    Just a Thought...
    Thanks for the tip, but i already had common layers between to 2 drawings.
    Much appreciated for the help guys, i now achieved a workaround to my problem which has now made my life a lot easier . I know where to come now if i have any further problems/queries. This forum is great!
    Regards,
    Scott
  9. #9
    Forum Newbie
    AutoCAD 2007
    Nov 2011
    1
    Default Another way to bypass this problem....
    Just copy the desired block in place using the COPY command (not COPYCLIP) then use cut (or Cntrl+X) an you will be able to paste it to the other drawing. I'll be happy to know why it cannot be copied (I believe it is deliberate). Anyone?
  1. issue with copy and paste
    By ali888 in forum AutoCAD Beginners' Area
    Last Post: 8th Jul 2009, 11:16 am
  2. Copy/Paste blocked !?
    By asptamer in forum AutoCAD General
    Last Post: 9th Apr 2007, 08:34 pm
  3. Copy and paste
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 29th Sep 2006, 01:23 am
  4. I can copy - but i can't paste!
    By ringo in forum AutoCAD Beginners' Area
    Last Post: 16th Sep 2005, 09:44 am
  5. Copy -> Paste problem - Help
    By AutoCAD Slave in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jul 2005, 12:47 pm
