I got this LISP a long time ago and forget where it originated from.
It rounds of "FACE3D,ARC,ATTDEF,ATTRIB,CIRCLE,ELLIPSE,INSERT,LI NE,POLYLINE,LWPOLYLINE,*TEXT,POINT,SHAPE,SOLID,TRA CE".
But I would like it to also round of the point of dimensions so they are at the same location as the newly positioned endpoints of the lines/polylines etc.
See here what dim point I refer to.
I don't know where to start to get that working.
Thanks.
Code:
(defun round_number (xr n / )
	(* (fix (atof (rtos (* xr n) 2 0))) (/ 1.0 n))
(defun c:FX_Round_Numbers ( / js n_count ent dxf_ent dxf_lst)
	(setq su (getvar 'SNAPUNIT))
	(setq tol (getreal "\nEnter the tolerance in X & Y: "))
	(setvar "SNAPUNIT" (list tol tol))
	(setq js (ssget '((0 . "FACE3D,ARC,ATTDEF,ATTRIB,CIRCLE,ELLIPSE,INSERT,LINE,POLYLINE,LWPOLYLINE,*TEXT,POINT,SHAPE,SOLID,TRACE"))) n_count -1)
	(cond
		(js
			(setvar "cmdecho" 0)
			(command "_.undo" "_group")
			(while (setq ent (ssname js (setq n_count (1+ n_count))))
				(setq dxf_ent (entget ent))
				(cond
					((eq (cdr (assoc 0 dxf_ent)) "LWPOLYLINE")
						(setq dxf_lst (cdr dxf_ent) dxf_ent (list (car dxf_ent)))
						(while (cdr dxf_lst)
							(if (eq 10 (caar dxf_lst))
								(setq dxf_ent (cons (cons 10 (mapcar '(lambda (x p) (round_number x (/ 1 p))) (cdar dxf_lst) (getvar "SNAPUNIT"))) dxf_ent))
								(setq dxf_ent (cons (car dxf_lst) dxf_ent))
							(setq dxf_lst (cdr dxf_lst))
						(setq dxf_ent (reverse dxf_ent))
					((eq (cdr (assoc 0 dxf_ent)) "POLYLINE")
						(while (eq (cdr (assoc 0 (setq dxf_ent (entget (entnext (cdar dxf_ent)))))) "VERTEX")
							(setq dxf_ent (subst (cons 10 (mapcar '(lambda (x p) (round_number x (/ 1 p))) (cdr (assoc 10 dxf_ent)) (append (getvar "SNAPUNIT") (list (car (getvar "SNAPUNIT")))))) (assoc 10 dxf_ent) dxf_ent))
							(entmod dxf_ent)
					(T
						(foreach n dxf_ent
							(if (member (car n) '(10 11 12 13 40))
								(if (listp (cdr n))
									(setq dxf_ent (subst (cons (car n) (mapcar '(lambda (x p) (round_number x (/ 1 p))) (cdr n) (append (getvar "SNAPUNIT") (list (car (getvar "SNAPUNIT")))))) (assoc (car n) dxf_ent) dxf_ent))
									(setq dxf_ent (subst (cons (car n) (round_number (cdr n) (/ 1 (car (getvar "SNAPUNIT"))))) (assoc (car n) dxf_ent) dxf_ent))
				(entmod dxf_ent)
				(entupd ent)
			;; TEST CODE TO UPDATE THE HATCH
			(command "_.move" (entlast) "" '(0 0 1e99) ""
							"_.move" "_p" "" '(0 0 -1e99) "")
			(command "_.undo" "_end")
			(setvar "cmdecho" 1)
			(setvar "SNAPUNIT" su)
			(princ (strcat "\n" (itoa n_count) " transformed objects (s)."))
		(T (princ "\nNo found valid object ."))
	(prin1)
