Results 1 to 9 of 9
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,304
    Default AutoCAD Will Not Work With LibreCalc - It Insist on Excel
    Had the chance to use an Excel spread sheet with a table full of data in it. But since I'm using LibreOffice and don't have Excel installed, AutoCAD kicks back an error saying no workie. So even if I save the file in *.xlsx format, AutoCAD will not work with it without out Excel being installed on the computer??? I thought it was more portable than that.
    It's deja vu, all over again.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,792
    Have you looked at say modifying something like getexcel.lsp to work with your libreoffice
    Code:
    (setq myXL(vlax-get-or-create-object "Excel.Application"))
    libreoffice equivalent ???
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,304
    That would be very cool, but this client uses LT and that means no lisp allowed. Oh the tragedies of life on a budget.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,792
    Have you thought about going the other way Excel has VBA write a script, pretty sure can cut and paste to LT a "Script" please let me know if thats incorrect.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,152
    But, he doesn't have Excel. I have yet to see anyone figure out a way to use Calc files with AutoCAD. Draw is similar to Visio and saves as .dwg, anyway to use the data in Draw then to AutoCAD?
    I'll move this to the AutoCAD LT forum, since that will limit the use of programing.
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,796
    Install the free trial of Microsoft Office 365, and run with it. Just remember to cancel before they take money out of your card.
    You'll be able to open the .xlsx file in Excel and then save it, tieing it to the right program.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,792
    Starting again.
    Does librecalc have macro ability ?
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,792
    Starting again.
    Had a quick look and yes no idea of what language.
    Bill please advise copy and paste a column to LT. Steven-g ?
  9. #9
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,174
    Looks to me as though Bill is trying to use a datalink and it does look as though that is setup to just work via excel and has to have excel installed, Autocad doesn't open xlsx files by itself,in the background it uses the sources inside excel to do that, and LT doesn't have a method to work with external files (no VBA or Lisp). The only way I could think of to use that would be paste from Librecalc as an OLE object basically just a pretty picture, there would be no way to interact with it. I had posted an answer some time last year about working with OpenOffice xls files in Autocad but I'm afraid that probably only worked because I still have Excel installed and it is that which made the link to an XLS file possible
    Going the other way is getting data out, and that would require the use of attributes and ATTEXT which will create a text or csv file and that should be readable by Librecalc
    @Bill what exactly are you trying to achieve, all is not lost just yet, BIGAL is onto something, I would imagine that Librecalc can use some form of programming or even just the basic concatenation of cells, so you might be able to create script files and copy paste that into Autocad to create a table or text items that can be linked with the field options, but this is just guesswork on my part (it's something I would be exploring about now to seeif it was possible).
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  1. Inserting excel data into autocad & making search panel in autocad
    By amb2301 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Sep 2017, 07:51 am
  2. Replies: 10
    Last Post: 8th Jun 2012, 09:55 pm
  3. autocad excel coordinate to excel
    By ses4 in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Apr 2011, 01:44 pm
  4. An AutoCAD Video Tip on Linking Excel with AutoCAD Tables.
    By Lynn Allen's Blog in forum AutoCAD RSS Feeds
    Last Post: 5th Aug 2010, 09:31 am
  5. How do I work from AutoCAD 2010 to AutoCAD 2009 edition??
    By Meglesniak323 in forum AutoCAD General
    Last Post: 14th May 2009, 10:18 pm
