Results 1 to 6 of 6
    Forum Newbie
    Surveying
    AutoCAD 2018
    Mar 2018
    7
    Default First steps in AutoLISP - too few / too many arguments
    Hello
    My first post here, so I will start with a brief introduction. I'm an engineering surveyor working in BricsCAD 18 (it's not listed as an option in this forum's registration form), most of my work is editing/tidying drawings exported from other software. I also do a fair bit of data manipulation in spreadsheets, and LISP is the next thing I want to get into.
    Unfortunately I have very limited time for troubleshooting. I wrote my first script today and guess what - too few / too many arguments. Can anyone cast their eye please?
    Code:
    (defun c:leveltext1103 (datum levpoint ydatum ypoint levdistance)
    (setq datum (getpoint "\nDatum line:"))
    (setq point (getpoint "\nSurvey point:"))
    (setq ydatum (cadr (datum)))
    (setq ypoint (cadr (levpoint)))
    (setq levdistance
    (rtos (* 2 (- point datum) 2 2))
    );setq
    (command "text" levpoint "0.15" "0" levdistance "")
    );defun
    The code is intended to produce a piece of text based on a scaled measurement of the y distance between two points on paperspace. Naturally this is just a dimension but I will later need to apply offsets etc to the calculation. I tried a few changes already and still get the error. I hope this is enough information for someone to resolve. Thanks in advance.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,489
    Code:
    (defun c:leveltext1103 ( / datum levpoint ydatum ypoint levdistance)
    Super Member
    not applicable
    Jun 2016
    699
    Actually there are more than 5 issues with the code.
    Code:
      (setq levpoint (getpoint "\nSurvey point:"))
      (setq ydatum (cadr datum))
      (setq ypoint (cadr levpoint))
      (setq levdistance
        (rtos (* 2 (- ypoint ydatum)) 2 2)
      ) ;setq
      (command "_.text" "_non" levpoint "0.15" "0" levdistance)
    ) ;defun
    BricsCAD 18
    Forum Newbie
    Surveying
    AutoCAD 2018
    Mar 2018
    7
    Thank you both for your rapid responses, that's great.
    Quote Originally Posted by Grrr View Post
    Code:
    I was going by this:
    It's a good idea to leave all variables as global whilst you are writing your
    program so that you can check their values during debugging.
    taken from the bottom of http://www.afralisp.net/autolisp/tut...e-function.php
    Is the advice on afralisp a bit oversimplified or am I missing something?
    Quote Originally Posted by Roy_043 View Post
    Code:
      (setq levdistance
      ) ;setq
    ) ;defun
    I've put red colour on any of your edits which I noticed. Coding is not forgiving, is it... Your code works! Did you make any more edits which I am missing?
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,792
    Re testing globally
    Code:
    ;(defun c:leveltext1103 ( / datum levpoint ydatum ypoint levdistance)
    (defun c:leveltext1103 ( )
    Sometimes though doing with global you will need to type say (setq datum nil) on command line to clear a variable.
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,489
    Quote Originally Posted by pateksan View Post
    Global variables.. well I hope you understand:
    (defun c:something ( <list of variables that are being localised for this function> )
    This means you didn't used global variables either,
    Main issue with your code is that you excluded '/' so your function became this structure:
    (defun example ( ex1 ex2 ex3 )
    where to call it you must provide arguments to it, like:
    (example "string" 1 (list "this" "is" "a list"))
    so if it was:
    (defun example ( / ex1 ex2 ex3 )
    the call would be just:
    (example)
    because now 'ex ex2 and ex3' are variables that the example functions uses inside.
    Yeah afralisp's examples are oversimplified and thats great for someone new to learn easily LISP.
    I'd suggest checking Lee Mac's tutorials, Localising Variables is related to your problem.
    Tho each tutorial requires very careful reading and re-reading it n-times, but you won't regret it.
  1. 4 steps
    By sergiu_ciuhnenco in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jan 2015, 01:54 pm
  2. AutoCad commands and their arguments in AutoLisp
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Nov 2012, 06:02 am
  3. How to define a function in AutoLISP with arbitrary arguments
    By Ahankhah in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Apr 2011, 06:54 pm
  4. 3D drawing of steps
    By Polly64 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Oct 2009, 12:21 pm
