Presentation renders, section plane, large files..
43st
I have a 260Mb assembly worked up over the last few months (50' dia. sphere construction, mechanics, etc.). I would like to render some sectionplane cuts and AutoCad (2016) isn't up for it. I've bound and cleaned all the references, but each block flakes out in it's own way, cutting some objects and not cutting others. The worst part is waiting several minutes between each command just to see if it worked or not.
Sometimes I can get a good conceptual viewbase section, but I'd like something rendered. Does Autocad have any type of working section plane other than the SECTIONPLANE command in model space? Outside of that.. Any recommended software that can actually do this? Navisworks? Showcase? Rhino even?
