Sengna Posted March 16, 2018 Share Posted March 16, 2018 (edited) Hello, Just very basic questions, thank you for all your feedback and input in advance. i came across toturial about 3 views othograpic projection, my questions are: 1. Is the space or distance A and B must be equaled in order to get the accurate when project the line to create the next view? 2. I assume the projection angle must always be 45 degree correct? Edited March 16, 2018 by Sengna clarify Quote Link to comment Share on other sites More sharing options...
lrm Posted March 16, 2018 Share Posted March 16, 2018 C should equal C and yes, the line should be at 45° Quote Link to comment Share on other sites More sharing options...
Sengna Posted March 16, 2018 Author Share Posted March 16, 2018 C should equal C and yes, the line should be at 45°[ATTACH=CONFIG]63515[/ATTACH] If C must be equal distance then A must be the same distance with B too right? Thank you Irm. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 16, 2018 Share Posted March 16, 2018 Well you could always run your own test by making A not equal to B then see what the results are. Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 16, 2018 Share Posted March 16, 2018 That's the purpose of the 45 deg line, simple plane geometry. Quote Link to comment Share on other sites More sharing options...
