Juergen Posted March 16, 2018 Share Posted March 16, 2018 Hi, I need a lisp that draw a point at the intersection axis extension of two picked Points at a Polygon. Or make this point as basepoint. (e.g. when I move the polygon) Thanks everybody for your help. [ATTACH]63511[/ATTACH][ATTACH]63511[/ATTACH] Quote Link to comment Share on other sites More sharing options...
benhubel Posted March 19, 2018 Share Posted March 19, 2018 It appears as if you have attached something, but I'm unable to view it. From what I'm understanding, you want to be able to pick an X point and a Y point. This will designate a point at the spot where they intersect? Also, did you want this to move the object right away, or are you trying to create a handle for future use? I have thrown together some quick code that does what I think you might want. It's definitely not bulletproof, but should be able to help get things started. (defun c:test ( / ss p1 p2 p3 ) (prompt "\nSelect objects to move.") (setq ss (ssget)) (setq p1 (getpoint "\nPick a point for X.")) (setq p2 (getpoint "\nPick a point for Y.")) (setq p3 (list (car p1)(cadr p2)(caddr p1))) ;get x and z value from p1 and y value from p2 (ssadd (entmakex (list (cons 0 "POINT")(cons 10 p3))) ss) ;create point (command "_.move" ss "" "_non" p3) ) Quote Link to comment Share on other sites More sharing options...
Juergen Posted March 20, 2018 Author Share Posted March 20, 2018 Hi benhubel, it´s exactly that what I need. Thx for your answer and help. Quote Link to comment Share on other sites More sharing options...
