muck Posted March 16, 2018 Share Posted March 16, 2018 How can idArray passed made to be used in another method or event in the same class after the above code is ran? placing "public static ObjectId[] idArray;" in the form general area does not work Code is given below: [CommandMethod("PICKFIRST1")] public void Pickfirst1() { Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor; Database db = HostApplicationServices.WorkingDatabase; Transaction tr = db.TransactionManager.StartTransaction(); try { TypedValue[] filList = new TypedValue[1] {new TypedValue((int)DxfCode.Start, "INSERT") }; SelectionFilter filter = new SelectionFilter(filList); PromptSelectionOptions opts = new PromptSelectionOptions(); opts.MessageForAdding = "Select block references: "; PromptSelectionResult res = ed.GetSelection(opts, filter); SelectionSet selSet = res.Value; // How can idArayy be made shared in another method? ObjectId[] public static ObjectId[] idArray; = selSet.GetObjectIds(); tr.Commit(); } catch (Autodesk.AutoCAD.Runtime.Exception ex) { ed.WriteMessage(("Exception: " + ex.Message)); } finally { tr.Dispose(); } } Thank you, Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 20, 2018 Share Posted March 20, 2018 Please read the Code Posting Guidelines and have your Code to be included in Code Tags.[NOPARSE] Your Code Here[/NOPARSE] = Your Code Here Quote Link to comment Share on other sites More sharing options...
