Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Full Member
    Mechanical
    Mechanical 2015
    Mar 2018
    25
    AutoCAD Lisp to Run a command Automatically when opened the file
    Hi All
    I have a bunch of files in a folder, I have to do the purging process on several files.
    I have a lisp file to open the file automatically,
    So my idea is, after open the file, if the file name having 7 digits then the purge command should run automatically, if the file name less/greater than 7 digits then command should not run. can we do through lisp if possible.?
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,152
    Hi,
    Create a acaddoc.lsp file if its not already existed into your AutoCAD support folder then add your codes into the fore-said file then within your codes you would need to have a few codes checking for the file name then do the job if your criteria matched.
    Full Member
    Mechanical
    Mechanical 2015
    Mar 2018
    25
    Hi Tharwat
    Thanks for your reply, If i add my code into acaddoc.lsp, this will run all the files whenever open my AutoCAD, but need if the file name having seven digits (ex. 1234_A3) then only purge command should run automatically.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    A simple check (getvar "dwgname") and have a look at is least 7 long does it have some pattern
    Code:
    (getvar 'dwgname)
    strlen is it 11
    subtract .dwg of end dont forget the 4 end characters .dwg
    substr in a loop 7 times check each character is it a number
    asscii 47-59 is 0-9
    Drawing1.dwg is 12 long so Drawing1 is 8 long
  5. #5
    Full Member
    Mechanical
    Mechanical 2015
    Mar 2018
    25
    Hey Bigal
    Can you please give me the code.. I'm not a expert in lisp. But I'm interested to learn. So please help me.
  6. #6
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    943
    this should help you on your way :
    Code:
    (defun c:tst ( / dwgn letters numbers)
      (vl-load-com)
      ; dwgname without path and extension
      (setq dwgn (vl-filename-base (getvar 'dwgname)))
      (princ (strcat "\nDrawing name is : " dwgn))
      (princ (strcat "\nDrawing name has " (itoa (strlen dwgn)) " characters"))
      ; Total number of letters in filename
      (if (> (setq letters (length (vl-remove-if '(lambda(x)(and (< x 58)(> x 47)))(vl-string->list dwgn)))) 0)
        (princ (strcat "\nTotal of letters in drawing name : " (itoa letters)))
        (princ "\nNo letters in dwgname")
      ; total number of numbers in filename
      (if (> (setq numbers (length (vl-remove-if '(lambda(x)(or (< x 48)(> x 57)))(vl-string->list dwgn)))) 0)
        (princ (strcat "\nTotal of numbers in drawing name : " (itoa numbers)))
        (princ "\nNo numbers in dwgname")
    ; a few tiny lisp functions for more general use :
    ; remove letters from string (ripcar "123abc456def") -> "123456"
    (defun ripcar (s)
      (vl-list->string (vl-remove-if '(lambda(x)(or (< x 48)(> x 57)))(vl-string->list s))))
    ; remove numbers from string (ripnum "123abc456def") -> "abcdef"
    (defun ripnum (s)
      (vl-list->string (vl-remove-if '(lambda(x)(and (< x 58)(> x 47)))(vl-string->list s))))
    gr. Rlx
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    Thanks rlx, nice descriptions, the question could cause other problems like purging a dwg you did not mean to. So acad1985 make sure you have a continue yes or no at start and for your info dcl supports a Ok Cancel button only, making a nice screen input rather than typing Y N etc. Which has prompted me to add to my library.
  8. #8
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,152
    Quote Originally Posted by acad1985 View Post
    A is a letter and not a digit.
    Can you explain your different file names in order to know how to check and run a program when a certain criteria meets.
  9. #9
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,152
    Hi rlx,
    Code:
    (length nil) ;; = 0
  10. #10
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    943
    Quote Originally Posted by Tharwat View Post
    Hi rlx,
    Code:
    (length nil) ;; = 0
    oh darn , I realized that right after I posted but hoped nobody would notice , but there's no fooling you is there ...haha
  1. Replies: 6
    Last Post: Today, 04:16 pm
  2. Replies: 1
    Last Post: 18th Sep 2014, 05:45 pm
  3. Execute lisp automatically while a command is running?
    By fathihvac in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th May 2013, 05:01 pm
  4. Replies: 0
    Last Post: 5th Nov 2008, 07:06 am
  5. Automatically goes to plot when a drawing is opened.
    By jrobpong in forum AutoCAD Drawing Management & Output
    Last Post: 26th Apr 2007, 12:54 pm
