amb2301 Posted March 16, 2018 Share Posted March 16, 2018 hi friends, i am using a software called spatialnet, while startup of this software,a lisp getting loaded automatically from the file path in c drive, actually i made some some modification in lisp, just changed the cursor size(17) & pickbox size(7) & executed that lisp, it works well, but nextday, whatever changes made in lisp gets disappears, again i am manually replacing that lisp. Kindly provide me some solution. my suggestion: is it possible to create a lisp like .... whenever autocad/spatialnet starts, it should replace the existing lisp located in file path(C:\Program Files\SPATIALinfo\SPATIALnet\bin64\spatialfm.lsp) with the new lisp file located in E drive file path(E:\AppData\spatialfm.lsp) Thanks in advance. Quote Link to comment Share on other sites More sharing options...
rlx Posted March 16, 2018 Share Posted March 16, 2018 option 1 : make the file read-only , option 2 : make a batch file with 1st line : copy e:\xxx.lsp c:\xxx.lsp , 2nd line start autocad , or option 3 , make new shortcut for autocad and in target field add /p option with your own (exported) profile name where you set your own favorite folders and put them above all others. Google knows all... gr. Rlx Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 16, 2018 Share Posted March 16, 2018 A 3rd when you change pickbox etc you may need to re-save your workspace and like Rlx a different profile may be worthwhile could have 2 different support paths so looks for correct file as other one is in a different support path not in current profile list. Quote Link to comment Share on other sites More sharing options...
