Create a Polygon by "Merging" 2 layers together while maintaining their properties.
ducky29
Hello I need to create a polygon using 2 different layers.
Let's say that I have 2 layers( magenta and cyan). Now I want to create a polygon using these two layers while still keeping their color(properties etc).
I tried using the topology feature but im unable to get the results that I want, as I always get an error.
Is there any way how to achieve the results that I want?
Thank you!
Unless Autodesk has added some new functionality in 2018, a polyline cannot be on two different layers at the same time. Also, a polyline can't have different colored line segments.
I would probably make two polyline objects. One of them would be the 3 sided magenta polyline and the other would be a 4 sided closed cyan polyline. Then I would set the Draworder so the magenta polyline is on top.
Thanks for the reply. I got the results by going to drawing cleanup --> create topology and then I exported the results to arcmap.
