ducky29 Posted March 17, 2018 Share Posted March 17, 2018 Hello I need to create a polygon using 2 different layers. Let's say that I have 2 layers( magenta and cyan). Now I want to create a polygon using these two layers while still keeping their color(properties etc). I tried using the topology feature but im unable to get the results that I want, as I always get an error. Is there any way how to achieve the results that I want? Thank you! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted March 17, 2018 Share Posted March 17, 2018 Unless Autodesk has added some new functionality in 2018, a polyline cannot be on two different layers at the same time. Also, a polyline can't have different colored line segments. I would probably make two polyline objects. One of them would be the 3 sided magenta polyline and the other would be a 4 sided closed cyan polyline. Then I would set the Draworder so the magenta polyline is on top. Quote Link to comment Share on other sites More sharing options...
ducky29 Posted March 19, 2018 Author Share Posted March 19, 2018 Thanks for the reply. I got the results by going to drawing cleanup --> create topology and then I exported the results to arcmap. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 20, 2018 Share Posted March 20, 2018 Seems to me you are not using AutoCAD. Those commands sound like AutoCAD Civil 3D and Map 3D. Quote Link to comment Share on other sites More sharing options...
