Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    notredave's Computer Details
    Vista :(
    HP
    Dual HP 23"
    Electrical
    notredave's Discipline Details
    Electrical
    E&I Designer
    AutoCAD 2009
    Jan 2012
    Louisiana
    36
    Default **Lisp routine to move text or mtext to midpoint of 2 points**
    Good morning all,
    Does anyone have a iisp routine that they can share that will first make mtext or text insertion point as MC for moving purposes and then be able move it to "mid between 2 points"? The text or mtext does not need to keep MC insertion point after moving it. I sure would appreciate it. I need to move alot of text on a nameplate schedule and want it to look professional. Cab wrote one years ago that works great if you have a rectangle but I need it to work for mid between 2 points.
    Link to Cab's post:
    https://forums.autodesk.com/t5/visua...e/td-p/2632882
    Thank you for reading,
    Dave
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    802
    Post a sample drawing.
    Senior Member
    StevJ's Computer Details
    Xp Pro
    AutoCAD 2014
    Sep 2008
    Bremerton, Wa
    140
    For text justification, see post 3 in http://www.cadtutor.net/forum/showth...ification-Lisp
    For centering text between two points, find your solution in http://www.cadtutor.net/forum/showthread.php?90741
    Steve
    Full Member
    Vista :(
    HP
    Dual HP 23"
    Electrical
    Electrical
    E&I Designer
    AutoCAD 2009
    Jan 2012
    Louisiana
    36
    ronjonp, attached is part of an example drawing
  5. #5
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    802
    You move each one of these texts one at a time ? Do you have code that generates the table?
  6. #6
    Full Member
    Vista :(
    HP
    Dual HP 23"
    Electrical
    Electrical
    E&I Designer
    AutoCAD 2009
    Jan 2012
    Louisiana
    36
    I don't mind moving one at a time. The table is generated manually. I just would like something to pick the text from middle center and picking 2 endpoints to center text. Did you happen to see Cab's lisp? It works but only if the second point is a rectangle. I would like to choose 2 points.
  7. #7
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    802
    IMO .. the first thing that should be done is figure out how to generate the table automatically. Then you can format to whatever needed.
  8. #8
    Full Member
    Vista :(
    HP
    Dual HP 23"
    Electrical
    Electrical
    E&I Designer
    AutoCAD 2009
    Jan 2012
    Louisiana
    36
    I have other type of drawings that use different size tables/schedules
  9. #9
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    802
    Quote Originally Posted by notredave View Post
    This is still a task to be automated...
    Here's some quick code to help you with your manual process.
    Code:
    (defun c:foo (/ _mid e p p1 p2)
      (defun _mid (p1 p2) (polar p1 (angle p1 p2) (/ (distance p1 p2) 2.)))
      ;; RJP - 03.22.2018
      (if (and (setq p1 (getpoint "\nSpecify first corner point: "))
    	   (setq p2 (getcorner p1 "\nSpecify other corner point: "))
    	   (setq e (ssget "_C" p1 p2 '((0 . "*text"))))
    	   (setq e (vlax-ename->vla-object (ssname e 0)))
    	   (vlax-write-enabled-p e)
        (progn (vla-getboundingbox e 'll 'ur)
    	   (setq p (mapcar 'vlax-safearray->list (list ll ur)))
    	   (vlax-invoke e 'move (_mid (car p) (cadr p)) (_mid p1 p2))
    (vl-load-com)
  10. #10
    Full Member
    Vista :(
    HP
    Dual HP 23"
    Electrical
    Electrical
    E&I Designer
    AutoCAD 2009
    Jan 2012
    Louisiana
    36
    I will try that and let you know. Thank you very much ronjonp!
  1. Auto lisp routine to bisect a line and draw a line perpendicular from midpoint
    By rvalusa22 in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Oct 2016, 08:28 pm
  2. lisp to place "points" at midpoint of pipe fittings
    By pipefitter72 in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Oct 2014, 02:33 am
  3. [LISP] First time writing LISP routine... trying to rotate, move and scale
    By chiimayred in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jul 2013, 06:02 pm
  4. Replies: 9
    Last Post: 3rd Jul 2012, 09:16 pm
  5. Lisp routine to convert objects into Text or Mtext
    By bsimpson in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Feb 2009, 01:31 pm
