convert all field to text
Hello!
Can you help me - which way convert all field to text in Autocad
Select all and { burst }
Sent from my Redmi Note 4X using Tapatalk
Mline text, blocks, dimensions can containt field. If I use burst, I will be crusched this object (Mline text, blocks, dimensions).
Exsits manual method to covert field to text - right button mouse -> convert to text. This action must be done with each field, but in dwg file may be to much field.
This is example file - needs what all field will convert to text and all object stay correct.
Now I have lisp (find in internet), but this lisp do not convert filed in dimension and main symbol "∅" diameter convert to symbol "?". In my dwg files too much symbols "∅".
example.dwg
fieldtotext.lsp
