Texts in Dimension 4 1/2" display arrangement.
You will need to use the DIMTFAC setting in your system variables.
Read the description in the screenshot from SYSVDLG.
You can also find this in OPTIONS, on the TEXT tab in the DimStyle Manager.
You don't want it set to 1, experiment until you find the relative size that you want to use. In the exmple you posted which you do not like, it is set to 1.
The one you like looks like about .75? :|
Edited by Dadgad
Thanks for your quick reply.
When I change DIMFAC to 0.6 it solved.
You're very welcome, glad I could help. :)
No doubt you are aware that there are other fraction display options available on the PRIMARY UNITS tab in the DIMSTYLE editor.
Edited by Dadgad
