Fuzzy MTEXT Problem. Need to explode and put Z=0.
3dwannab
Hi,
Please see attached the Fuzzy Text Problem.dwg
The bottom of the two text (MTEXT) has a Z value of 0.
When exploded to TEXT it has a value of -0.00000454.
It appears FUZZY in AutoCAD for this reason.
2d wireframe is set
DVIEW is ok also.
FLATTEN or my routine below for putting objects to Z won't work either.
(defun C:FX_Flatten_To_Z ()
(command "_.UCS" "")
(command "_.move" "_all" "" '(0 0 1e99) ""
	"_.move" "_p" "" '(0 0 -1e99) "")
Any insight to this problem would be great, thanks.
Run the LIST command on your lower MTEXT object and look at the "Normal".
It's 0.00000000 -0.00000001, 1.00000000
The Y value should be 0.0 also.
1. Make a new mtext object (content and properties do not matter) next to or below this one.
2. Copy and paste the contents from the bad on into the new one.
3. Run Match Props (Command: MA) to copy the properties from the bad one, to the new one.
4. Erase the bad object.
Thanks. I very rarely use the LS command.
Never knew such as thing as normals existed in AutoCAD.
I have Lee Macs CopySwapTextV1-7.lsp to quickly copy text contents to another text object with options for keeping formatting or not.
Now to investigate if a lsp program can mod the normal value as I come across this on a lot of drawings the come in.
Yes, it can be done. You might want to figure out what (or who) is creating the entities like that, and fix the source problem.
I've got help with this code.
I'm going to try get it to work with multiple objects.
I can't approach the culprits as I'm not directly involved with them. This is just the tip of the iceberg when it comes to problems with their drawings. :glare:
