Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Send to PDF
    Full Member
    Mechanical
    AutoCAD 2015
    Nov 2017
    93
    Default Send to PDF
    I have written a send a .dwg to .pdf routine and it is not working.
    Here are the plot settings.
    Any ideas?
    Code:
    (defun c:SendToPDF ( / *error* vars old s file Fname fsl dwgN)
       (defun *error* ( msg )
          (and old (mapcar 'setvar vars old))
          (princ (strcat "\n** Error: " msg " **")))
       (setq vars '("CMDECHO" "FILEDIA") old (mapcar 'getvar vars))
       (mapcar 'setvar vars '(0 0))
       (setq dwgN (getvar "dwgname"))
       (setq fsl (strlen dwgn))
       (Setq Fsl (- fsl 4))
       (setq Fname (substr dwgn 1 fsl))
       (setq Fname (strcase fname t))
       (setq file (strcat (getvar 'DWGPREFIX) (substr (setq dwg (getvar 'DWGNAME)) 1 (- (strlen dwg) 4)) ".pdf"))
       (while
             (setq s (getstring (strcat "\nEnter Filename for Save <" (getvar 'file) "> : ")))
             (cond ( (eq "" s)
             (setq s (getvar 'DWGNAME)) nil)
             ( (not (snvalid s))
             (princ "\n** Invalid **")))
    (setq path (getvar "dwgprefix"))
    ; (command "_.saveas" "_2010" (strcat "G:\\Group\\2D AutoCAD\\HDAL Library\\" s))
    ;(command "_.saveas" "_2007" (strcat path s))
      (command "-plot"         "yes"           ""              "DWG TO PDF.PC3"
               "ANSI expand B (11.00 x 17.00 Inches)" "Inches"        "Landscape"     "yes"           "Extents"
               "yes"           "yes"               "yes"           "monochrome.ctb"       "yes"
               "no"            "no"            "yes"           file            "no"            "Yes"
    Greg
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    943
    I'm not sure because I haven't tested your routine but does it maybe fail on the paper size? You don't mention... I ask because I had this problem once and after I replaced the spaces in my paper size with underscores it worked...
    Full Member
    Mechanical
    AutoCAD 2015
    Nov 2017
    93
    Quote Originally Posted by rlx View Post
    Thanks. I will give that a shot and see what happens.
    Greg
    Senior Member
    Manufacture
    BrianTFC's Discipline Details
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    183
    GregGleason,
    try this.
    Code:
    (defun c:Test()
          (vl-load-com)
          (if (setq filename (getfiled "Save File Location" ""  "pdf" 1))
          (command "-plot" "yes" "" "DWG To PDF.pc3" "ANSI expand B (11.00 x 17.00 Inches)"
              "inches" "landscape" "yes" "Extents"
              "fit" "center" "yes" "monochrome.ctb" "yes" "a" filename "no" "yes")
  5. #5
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    943
    Probably Brian's suggestion will work so just show where you went wrong:
    to make the file name try his :
    Code:
     (setq file (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".pdf"))
    also :
    Code:
    file is not a system variable so it should be :
    Code:
     (setq s (getstring (strcat "\nEnter Filename for Save <" file "> : ")))
    hope this helps
    gr. Rlx
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,421
    2c - I'd store the file lisp variable like this:
    Code:
    (setq file (apply '(lambda (a b c) (strcat a b ".pdf")) (fnsplitl (apply 'strcat (mapcar 'getvar '(dwgprefix dwgname))))))
  7. #7
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    943
    Quote Originally Posted by Grrr View Post
    Code:
    make it 20 dollar cause never seen this construct haha
  8. #8
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,421
    Haha.. cheers!
  9. #9
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    There is a lot more you can do like plot a range of layouts to pdf's, make a single pdf of a range etc. You will need to down load and install ghostscript seperately for the combine routine.
  10. #10
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    943
    AH! now the biting makes sense! fnsplitl is a real function....
  1. Trying send image
    By Luancat in forum Feedback
    Last Post: 12th Dec 2015, 01:34 pm
  2. not to send macros with dwg
    By dusko in forum AutoCAD General
    Last Post: 26th Oct 2009, 05:14 pm
  3. Add Arc using send command
    By lewis770227 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jan 2009, 02:56 pm
  4. Little help with send command
    By Barry Clark in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Feb 2006, 03:00 pm
