Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member
    AutoCAD 2015
    Jan 2015
    131
    Default vl-file-delete returns always nil + suggestion
    Hi there!
    I've wrote this lisp in order to make a little bit faster the cleaning of the output of my FEM.
    I don't understand why I'm not able to delete the source dxf. What's wrong?
    Code:
    (defun C:arm (/ laylist)
    (_SetCLayer "BORDO")
      ;(command "._layer" "_OFF" "*" "_YES" "")
      (setq laylist (list "ARMAT_INF_DIR_X"
                      "ARMAT_INF_DIR_Y"
                      "ARMAT_SUP_DIR_X"
                      "ARMAT_SUP_DIR_Y"
                      "BORDO"
    (foreach ln laylist
    (if (tblsearch "LAYER" ln)
    (command "_.LAYER" "_LOCK" ln "")
    (princ (strcat "\nLayer " ln " Blocked"))
      (command "_.ERASE" "_ALL" "")
    (foreach ln laylist
    (command "_.LAYER" "_UNLOCK" ln "")
    (princ (strcat "\nLayer " ln " Now Visible"))
      (command "_.purge" "_all" "" "_no")
      (command "_.erase" (ssget "_A" '((420 . 85))) "")
      (setq filename (strcat (getvar "dwgprefix")(getvar "dwgname")))
      (command "_.save" "" "_Y")
      (vl-file-delete filename)
      (command "_.close" "")
    May I ask a suggestion? I use the dwg as xref in my drawings. I import it 4 times and change the layer visualization.. There is a way to generate 4 dwg with these layers: BORDO + ARMAT_INF_DIR_X, BORDO + ARMAT_INF_DIR_Y, BORDO + ARMAT_SUP_DIR_X, BORDO + ARMAT_SUP_DIR_Y ?
    Thanks for your help,
    Dennis
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    943
    you cant delete a file that is in use (like an active drawing)
    Senior Member
    AutoCAD 2015
    Jan 2015
    131
    Hi rxl, in the code I saved the file as .DWG and this is the current not the one I'm trying to delete.
    Look at the code: I get the name of the file before the save, i try to delete it after the save.
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    943
    well to use Grrr's code and assuming it is the dxf you want to delete :
    Code:
     (setq filename (apply '(lambda (a b c) (strcat a b ".dxf")) (fnsplitl (apply 'strcat (mapcar 'getvar '(dwgprefix dwgname))))))
    else you will have to first close the drawing before you can delete it.
    p.s. And you may want to use saveas instead of save...
    gr. Rlx
  5. #5
    Senior Member
    AutoCAD 2015
    Jan 2015
    131
    With this code I get the same as mine, anyway the vl-file-delete doesn't delete the dxf. Maybe it's something related to permissions?
  6. #6
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    943
    Quote Originally Posted by MastroLube View Post
    did you try saveas first?
  7. #7
    Senior Member
    AutoCAD 2015
    Jan 2015
    131
    Hello!
    Yes, i tried:
    Code:
      (setq filename (strcat (getvar "dwgprefix") "arm"))
      ;(command "_.save" "" "_Y")
      (vla-SaveAs (vla-get-ActiveDocument(vlax-get-acad-object)) filename ac2004_dwg)
      (vl-file-delete (strcat filename ".dxf"))
    Unfortunately it looks like that after _.close the lisp stops to work. :S
    EDIT: I really don't know.. event putting the (vl-file-delete .. or the command _.del I'm not able to delete this file..
    With the saveas the dxf isn't the current anymore so i don't know what to do..
  8. #8
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    943
    Hello!
    Yes, i tried:
    Code:
    just loose the close... when you open the dxf , it becomes active. When you just use save, you make a dwg but you're still in the dxf. When you saveas the dxf to dwg , the dwg becomes active and you can delete the dxf.
  9. #9
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    943
    something like this :
    Code:
    (defun c:dxf2dwg ( / dwg old-exp)
      (vl-load-com)
      ; no nagging when dwg allready exists , don't use if you don't want to overwrite existing dwg's
      (setq old-exp (getvar "EXPERT"))(setvar "EXPERT" 2)
      (setq dwg (strcat (getvar "dwgprefix")(vl-filename-base (getvar "dwgname"))))
      ;(vla-SaveAs (vla-get-ActiveDocument (vlax-get-acad-object)) dwg ac2004_dwg); doesn't seem to release dxf
      (command ".saveas" "" dwg) ; looks like this works better
      (gc) ; garbage collection, a little flushing after save / write never hurt anybody
      (vl-file-delete (strcat dwg ".dxf"))
      (setvar "EXPERT" old-exp)
  10. #10
    Senior Member Jef!'s Avatar
    AutoCAD 2008
    Sep 2010
    274
    I concur. Not only that, the lisp execution is local to a specific drawing. When you close the drawing the lisp just hangs there even if the command/commands/vlcmf close / vla-quit/exit is the last thing in the lisp.. I use to use a very simple lisp, when a drawing was opened it opened it a 2nd time in read only and closed the first one. Used 31 times no more drawing could be opened in the session a popup would appear saying something like that "a maximum of 32 drawings can be opened per session". Referred by some as a bug, maybe because I seem to be able to qnew more than 32 dwgs, but it is like using close/quit/exit leave some things in a stack somewhere (like probably local variables not getting out of scope)..
    My guess here is that whenever you manipulate files fast (like saveas and delete previous file, or closing and deleting a file right away), depending on the action and various other things, cad could/will end up trying to delete the file before windows has released the file's handle, making the action fail. Try adding a delay before the call to delete the file.
    Different goal also quite often means different path...
  1. Delete layers of a linked DWG file
    By halam in forum Revit Structure
    Last Post: 22nd Jan 2016, 04:11 pm
  2. how to delete useless .dwg file when using .dwt
    By dunno790 in forum AutoCAD Beginners' Area
    Last Post: 11th Nov 2015, 08:56 pm
  3. Assembly File Delete.
    By Jake8090 in forum Autodesk Inventor
    Last Post: 4th Jun 2014, 09:09 pm
  4. Delete a script file thru lisp after running
    By svorgodne in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Jun 2013, 12:07 am
  5. *.AC$ file - okay to delete huge files?
    By tzframpton in forum CAD Management
    Last Post: 18th May 2011, 01:41 pm
