Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Senior Member
    Mechanical
    Plant 3D not applicable
    Feb 2018
    123
    Wink smal code to find itself LOL
    Dear coders
    I was playing a little with the find file function and pure for learning I was wondering if it is possible to make a lisp that will find himself
    ATM I don't know what code to use to get the filename and the path of the LSP file
    I am not looking for another file then where the code is written in
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,057
    You can check if a command is loaded with '(if c:my-func ... or with atoms-family , but you would still have to know in advance the filename containing your function definition. Or you would have to instruct your lisp file to set a global variable / list / array with it's path in it. Of course if you have many files that use a function called test that would be a little problematic. Also possible would be consistency between name of function and name of lisp file , function c:mylisp1 -> mylisp1.lsp. Whatever way , it can be done but think it has to be by design. Else you have scan for all lisp files , open them and see if a certain function lives inside... so if you want it , you have to plan it.
    gr. Rlx
    Senior Member
    Mechanical
    Feb 2018
    123
    @rlx
    Well that is hard coz I do not know where the file will be saved but I do need to do stuff with it like setting attributes (read-only o.i.d.) or simply delete the file or move it from where it is now to an specific folder
    Senior Member
    Mechanical
    Feb 2018
    123
    And the (dos_lisplist [T]) is not reliable because it gives back more then my custom loaded lsp files but less then what you can see with appload LOL
  5. #5
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,057
    that's why all my (active) lisp files live together as one big little house on the prairie family in the same folder and this folder is at the top of my supportpath so findfile will always find it. Think Lee has a find-file routine , I have one too in my batch generator, don't know if I have all the subfunctions else search for RlxBatch
    Code:
    ; find drawing objects - Thanks to TonyT, (probably) no way I would have been able to think this up, credit where credit's due
    ; just compressed and tweaked it a little bit
    (defun load_fso_scripting ( / server fso:progid fso:prefix )
      (setq fso:progid "Scripting.FileSystemObject" fso:prefix "wsh-")
      (if (not wsh-get-drives)
        (if (not (setq server (CoGetClassServer fso:progid)))
          (alert "Error: Windows Scripting Host is not installed")
          (vlax-import-type-library
     :tlb-filename Server :methods-prefix fso:prefix :properties-prefix fso:prefix
     :constants-prefix (strcat ":" fso:prefix)))))
    (defun ProgID->CLSID (ProgID)(vl-registry-read (strcat "HKEY_CLASSES_ROOT\\" progid "\\CLSID")))
    (defun CoGetClassServer (progid) (CoGetClassProperty progid "InprocServer32"))
    (defun CoGetClassProperty (ProgID property / clsid)
      (if (setq clsid (ProgID->CLSID ProgID)) (vl-registry-read (strcat "HKEY_CLASSES_ROOT\\CLSID\\" clsid "\\" property))))
    ; FInd Drawing Objects - test : (setq lst (fido (dos_path "d:/temp/lisp")))
    ; network test : (setq lst (fido (dos_path "//sabiccorp.sabic.com/eur/boz/Technical_Department/Acad.net/templates")))
    (defun fido ( $f / fso fld rslt)
      (load_fso_scripting)
      (setq fso (vla-getInterfaceObject (vlax-get-acad-object) "Scripting.FileSystemObject")
     fld (wsh-GetFolder fso $f) rslt (fifo fld "*.dwg")) (vlax-release-object fld) (vlax-release-object fso) rslt)
    ; (setq lst (find-files (dos_path "d:/temp") "*.tif"))
    (defun find-files ( $f $e / fso fld rslt)
     fld (wsh-GetFolder fso $f) rslt (fifo fld $e)) (vlax-release-object fld) (vlax-release-object fso) rslt)
    ; find in folders fl=file ,fls=files, sf=subfolder, sfl=subfolderlist, res=result
    (defun fifo ( %dir %ext / fl fls sf sfl res)
      (vlax-for fl (setq fls (wsh-get-files %dir))
        (if (wcmatch (strcase (wsh-get-name fl) t) %ext)(setq res (cons (wsh-get-path fl) res)))(vlax-release-object fl))
      (vlax-release-object fls)
      (vlax-for sf (setq sfl (wsh-get-SubFolders %dir)) (setq res (append res (fifo sf %ext)))(vlax-release-object sf))
      (please_release_me_let_me_go (list sfl)) res)
    (defun dos_path  ( $p ) (if (= (type $p) 'str) (strcase (vl-string-translate "/" "\\" $p))   ""))
    (defun please_release_me_let_me_go (lst)
      (mapcar '(lambda(x)
          (if (and (= 'vla-object (type x)) (not (vlax-object-released-p x)))
            (vlax-release-object x))(set (quote x) nil)) lst))
  6. #6
    Senior Member
    Mechanical
    Feb 2018
    123
    I have to approach this different @RLX
    I think I have to make adjustments and hardcode the filename inside the LSP and use FINDFILE to get the path
  7. #7
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,057
    sounds like a plan
  8. #8
    Senior Member
    Mechanical
    Feb 2018
    123
    LOL
    Going to block all other LSP files in use here if they do not have the "Check" build in
    A lot of designers are not going to like this ( have no other choice atm until I find a good solution )
    No I am the IT guy who screws with the coders
  9. #9
    Senior Member
    Mechanical
    Feb 2018
    123
    someone made C++ code for it
    need visual studio to compile
    http://tbn2.blogspot.com.br/2014/06/...o-autocad.html
  10. #10
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,057
    Quote Originally Posted by DGRL View Post
    LOL
    glad you're not my boss hahahaha
  1. code to find current cad version
    By wimal in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Oct 2014, 02:31 am
  2. Replies: 6
    Last Post: 13th Jul 2011, 02:19 pm
  3. Find, Can't Find Square Bracket "["
    By jamesfear in forum AutoCAD General
    Last Post: 4th Aug 2010, 12:45 am
  4. [code] text [/code]
    By lpseifert in forum Feedback
    Last Post: 19th Jul 2010, 11:12 am
  5. Can't find DCL control code for text size...
    By LSR in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Nov 2006, 10:09 pm
