Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    Default How to display angles and line lengths in autocad
    Hi,
    I cannot find the command that makes the program display the length and angles of the lines in relation to eachother.
    I am doing a 2 dimensional masterplan with 70 houseplots and I need to be able to see that the boundrylengths and angles are correct.. If anyone knows about this the info would be much appreciated
    Thanks
    N
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Not sure your question, but...
    LIST will give you the length and angle of a line
    PROPERTIES will also
    ..but doesn't give data "in relation to one another", it gives angles in relation to the datum defined in the UNITS settings. Usually 0 degrees is a oriented to the right, positive x direction.
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    Thanks for the response.
    I was not clear before though..
    I know how to check the lengths angles etc in the Cad program. But i want the program to post those angles/lengths on the screen so that when I look at the screen, or print the paper, I can see how long all the house borders are, how wide the roads are etc.
    That is : I want the program to "show" the length etc on screen and on print for all lines.
    thanks
    N
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    How about dimensioning?
  5. #5
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    Dimensioning?
    I should add that I have a spanish version of autocad.. I speak the language somewhat but the specific words might be different..
    If you could send something like: under "tools" menu there is xxx - inside there you choose xxx it would be great
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    Under "Dimension" menu there are "Linear" and "Angular" which write the lengths and angles on the drawing.
  7. #7
    Forum Newbie
    AutoCAD 2006
    Nov 2006
    5
    That works, thanks.
    Downside is that I will have to redraw all lines (exchange them for the other type of line that tells the length)
    Is there no way to make the length show in the "normal lines" rather than drawing the new type of lines over the old ones?
    (I am hoping for something like right click on xxx and show xxx properties)?
    Thanks for continuing help by the way, very appreciated
  8. #8
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    You said that you wanted to leave the lengths and angles on the drawing, not just to inspect them in AutoCAD, and Dimension does just that.
    After you have drawn the dimension, you can always explode the dimension which will leave you with the length and angle as text, but you will have to clean up all the leaders and extension lines, etc.
  9. #9
    Forum Newbie
    AutoCAD 2004
    Jul 2008
    3
    Default elbow lisp routine
    I am looking for a round mitered elbow lisp routine.Can anybody help
  10. #10
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    Quote Originally Posted by Mark Eiberg View Post
    Considering the original thread title How to display angles and line lengths in autocad, yours is a peculiar reply.
    Try starting a new thread in the appropriate section, and you will get a sensible answer.
  1. Line Lengths
    By BSouders in forum AutoCAD Beginners' Area
    Last Post: 19th Apr 2006, 09:12 am
  2. shoulder lengths on leaders (autocad lt 2002)
    By ALEX3020 in forum AutoCAD Beginners' Area
    Last Post: 11th Oct 2005, 12:44 pm
  3. How to extract Attribute data and display within AutoCAD?
    By scootermac in forum AutoCAD Drawing Management & Output
    Last Post: 13th Sep 2005, 02:47 am
  4. total line lengths by layer
    By Mark Thomas in forum Tutorials & Tips'n'Tricks
    Last Post: 13th May 2004, 05:01 pm
  5. AutoCAD Display Order
    By Marie in forum AutoCAD Drawing Management & Output
    Last Post: 6th Dec 2002, 03:37 pm
