Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 29
  1. #11
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    966
    Quote Originally Posted by lido View Post
    (vl-cmdf "abcde") return: Unknown command "abcde". Press F1 for help. T
    (command "abcde") return: Unknown command "abcde". Press F1 for help. nil
    Finally, always vl-cmdf function return T and command function return nil.
    How could I manage an error like "Unknow command" without an error code??
    Testing the AutoCAD version may be a path... But if the client uses an other CAD platform? First test the platform (PROGRAM system variable). Then test the version (VERNUM system variable) and decide if EATTEDIT is implemented or not by reading specific CAD manuals. No, please...
    mabe app needs rewrite or better error catching
    Code:
     (setq test (vl-catch-all-apply 'command-s (list "eattedit"))) vs (setq test (vl-catch-all-apply 'command-s (list "lido-edit")))
    but if client uses other CAD platform you're even further from a solution. but doesn't (Roy's) getcname work?
  2. #12
    Forum Newbie lido's Avatar
    lido's Computer Details
    Windows 10 x64
    Multi-disciplinary
    AutoCAD 2005
    Jan 2017
    9
    I tried these functions before posting on this forum!
    Under AutoCAD 2015:
    (getcname "_eattedit") return nil
    (getcname "eattedit") return nil
    (= (type 'eattedit) 'sym) return T
    (= (type 'abcde) 'sym) return T
  3. #13
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    838
    Then learn to ask a better question.
    "Describe the diagnostic steps you took to try and pin down the problem yourself before you asked the question."
  4. #14
    Windows 10 x64
    Multi-disciplinary
    AutoCAD 2005
    Jan 2017
    9
    Catching error with vl-catch-all-apply and vl-catch-all-error-p functions are OK but don't solve the problem entirely. Because of command-s function. Using command or vl-cmdf functions, fails.
    Unfortunately, the command-s function is not implemented under older AutoCAD releases (e.g. AutoCAD 2000) or under some CAD platforms (e.g. ZWCAD).
    So, in my opinion, the only way to solve the problem is by getting that damn list of all built-in AutoCAD commands. It is possible or not?
  5. #15
    Windows 10 x64
    Multi-disciplinary
    AutoCAD 2005
    Jan 2017
    9
    Sorry mr. ronjonp for wasting your time.
    Aggression cannot, under any circumstances, solve none problem!
  6. #16
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    966
    Maybe a certain L(ist) M(anipulator) has some bright idea or knows of a undocumented command. But I am curious ,if and when you know eattedit is not available , what are you gonna do with this knowledge. Just display a message with sorry command not available or do you have a backup routine? I think there are more than enough people on this site able and willing to help you to rewrite your routine or just the part you need. Just 'be kind & rewind' ...
  7. #17
    Super Member
    not applicable
    Jun 2016
    669
    To my knowledge there is no way to obtain a list of command names via Lisp code.
    For _eattedit and other commands that require user input something like this should work (on most CAD platforms I believe):
    Code:
    (defun CommandAvailable_P (cmd / ret)
      (setvar 'cmdecho 0)
      (command cmd)
      (setq ret
        (if (zerop (getvar 'cmdactive))
            (princ "\r") ; Remove: 'Unable to recognize command "ABC". Please try again.' prompt.
            nil
            (command nil)
            T
      (setvar 'cmdecho 1)
      ret
    BricsCAD 18
  8. #18
    Super Member
    not applicable
    Jun 2016
    669
    FYI: getcname works fine in BricsCAD:
    Code:
    (getcname "_eattedit") => "EATTEDIT"
    (getcname "_doesnotexist") => nil
    BricsCAD 18
  9. #19
    Windows 10 x64
    Multi-disciplinary
    AutoCAD 2005
    Jan 2017
    9
    Thank you very much Roy_043.
    Using the system variable CMDACTIVE is the key!
    I never think about this approach. Brilliant.
    Thank you one more time.
  10. #20
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    657
    Just test only..
    Code:
    ;At this level we can list out
    (vl-registry-descendents  (strcat "HKEY_LOCAL_MACHINE\\"
    		 (vlax-product-key)
    		 "\\Applications\\")
    ;but why this level doesn't work ???
    	  (vlax-product-key)
    	  "\\Applications\\"
    	  "AcEAttEdit"
    	  "\\Commands"
    another approach
    Code:
    (defun foo (app ac cmd)
      (and (setq app (findfile app))
           (vl-registry-read
    		 (vlax-product-key)
    		 "\\Applications\\"
    		 ac
    		 "\\Commands")
    		 (strcase cmd )
    Code:
    _$ (foo "AcEAttEdit.arx" "AcEAttEdit" "EATTEDIT")
    T
    _$ (foo "AcTable.arx" "AcadTable" "EATTEDIT")
    nil
    _$ (foo "AcTable.arx" "AcadTable" "TINSERT")
    T
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  1. How to Getvar from List Command Autolisp..?
    By GopinadhGvs in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Apr 2015, 02:40 pm
  2. How to utilize built-in Rotate command with SelectionSet?
    By Alex_AMF in forum .NET, ObjectARX & VBA
    Last Post: 3rd Dec 2014, 04:08 pm
  3. Is it possible to add a button/icon for an AutoLISP command to AutoCAD?
    By jjatho in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Jul 2013, 08:02 am
  4. Tutorial: Create a custom command for AutoCAD using AutoLISP
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 16th Jul 2012, 08:50 pm
  5. Command List Updated for AutoCAD R12 through AutoCAD 2009
    By HyperPics in forum AutoCAD RSS Feeds
    Last Post: 18th Jul 2008, 03:30 pm
Tags for this Thread
