Results 1 to 4 of 4
    Forum Newbie
    AutoCAD LT 2002
    Nov 2006
    2
    Default Re-Installation of Cad
    Hi All,
    Hope I am in the correct forum. Also, sorry to perhaps cover old ground, but I am an IT support engineer and am having to rebuild a dead pc that had LT 2004 installed. As i have access to the original hard drive folders, can I copy any files from the original application that will re-configure the new application the same as the original. Sort of a config file shall we say with the users preferences. Thanks for any help available.
    Regards
    Scoffagus.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,639
    That is hard to answer. It depends on where the user stored these files, if any were stored in a non-default place.
    It also depends on what exactly was customized.
    The AutoCAD "profile" is stored in the registry. This includes things like the background color, the support file search path, location of dialogs, user options, etc.
    Forum Newbie
    AutoCAD LT 2002
    Nov 2006
    2
    Hi There.
    Thanks for taking the time to reply to my query. At least I can't be sniped at for not re-configuring his cad as it was.
    Thank you.
    Regards
    Scoffagus
    Forum Newbie
    AutoCAD LT 2007
    May 2010
    2
    Default duplicate profile registry data across multiple user accounts
    Hi,
    Would there be a way to duplicate that registry data across multiple user accounts? Specifically that of new users to a machine.
    I am trying to setup 2 AutoCAD computers for remote desktop. Currently the user logs on with credentials through a company domain controller and their user account is created.
    My problem is that when I specify locations for:
    -Plot and Publish Log file Location
    -Template Settings > Drawing Template File Locations
    -Printer Support File Path > Printer Configuration Search Path
    -Printer Support File Path > Printer Description File Search Path
    -Printer Support File Path > Plot Style Table Search Path
    -Customization Files > Main Customization File
    And define in plot settings:
    -the page setup name,
    -Default Printer,
    -Plot Style table,
    -Plot options,
    Etc…
    That these settings are not preserved between newly created user accounts. These changes can only be observed on my user account. I have copied my user account over the default user. However new users still don’t see these changes.
    Note: I am aware, that the default user option only applies to new users, not those who have previously logged in.
    Any help would be appreciated. I have already wasted most of a day on this.
    Thank you kindly,
    Aaron
  1. Using log to troubleshoot installation errors
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 14th Nov 2006, 05:48 pm
  2. Autocad 2007 installation
    By pab006 in forum Software & Licensing
    Last Post: 10th Apr 2006, 11:51 pm
  3. AutoCAD installation problems
    By Jonosss in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2005, 08:06 am
  4. express tools installation
    By jt6572 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Feb 2005, 01:59 am
  5. After installation Viz 4 not working
    By Hakan Kisacik in forum 3ds Max General
    Last Post: 31st Oct 2002, 09:56 pm
