Results 1 to 7 of 7
    Forum Newbie
    Architectural
    AutoCAD 2016
    Sep 2017
    9
    Default Change color (RGB) of objects in a selection set
    Hello together,
    I thought I have a simple task to perform, but unfortunately it turned out to be more difficult than I expected:
    I have in my lisp a code to select all elements in a drawing using (setq tbe (ssget "_X")), what I want to do now is to change the color of the selectionset to have a certain color. This color is defined by the RGB code 102,204,255.
    Unfortunately I was not able to find the important hint to solve it by my own
    Thank you for your help,
    Ament
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    802
    Try this:
    Code:
    (defun c:foo (/ s)
      (if (setq s (ssget ":L"))
        (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
          (entmod (append (entget e) '((420 . 6737151))))
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    622
    recent thread ?
    by grrr & M.R
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
    Forum Newbie
    Architectural
    AutoCAD 2016
    Sep 2017
    9
    Hi nahhphuc, unfortunately I'm a beginner in LISP and not able to identify the relevant code in the threat you mentioned Could you give me the hint?
  5. #5
    AutoCAD 2007
    Apr 2013
    Happy Garden
    622
    http://www.lee-mac.com/runlisp.html
    you can try copy the entire code by Ronjonp @ post#2 (shorter)
    paste to command line
    to invoke type,
    command : foo
    or
    (c:foo)
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,421
    Back then, when I was learning about grread: Grread + RGB (featuring the help of two giants).
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    To convert the rgb use lee-mac function
    Code:
    ;; RGB -> True  -  Lee Mac
    ;; Args: r,g,b - [int] Red, Green, Blue values
    (defun LM:RGB->True ( r g b )
        (logior (lsh (fix r) 16) (lsh (fix g) 8) (fix b))
    ;(setq rgb (LM:RGB->True R G B))
    (setq rgb (LM:RGB->True 102 204 255))
    ;6737151
  1. Multiple selection to change color
    By Romero in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Nov 2016, 10:36 am
  2. Replies: 15
    Last Post: 16th Jul 2013, 05:20 pm
  3. Lisp to change all objects with a certain color to another color
    By mikeSIEMENS in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jan 2010, 04:59 pm
  4. How To Change and Objects Color With Vla????
    By BLOACH85 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Mar 2009, 06:01 pm
  5. can't change color of objects
    By moose321 in forum AutoCAD Drawing Management & Output
    Last Post: 24th Oct 2007, 04:31 am
