Dynamic Blocks visibility and insert scales
wimal
When we insert a dynamic block to a difference X Y scales, the visibility state does not functioning.Is there any lisp codes to reset the visibility states.
If you want to reset the block you can use the resetblock command even if the block is not uniformly scaled to return it to its original state.
If you want to chose and set any other look at Lee Mac's site here, it works on dyn blocks regardless of their scale
http://lee-mac.com/dynamicblockfunctions.html
You will need
LM:SetVisibilityState
LM:setdynpropvalue
LM:getdynpropallowedvalues
LM:getvisibilityparametername
You will need
LM:setdynpropvalue
Great help. Now I can go ahead. Thanks a lot
