Results 1 to 5 of 5
    Forum Newbie
    Construction
    Electrical 2016
    Apr 2018
    2
    Default watercolor - non uniform hatch
    Hello, I'm looking for some help in the task of making my plans less boring. I'd like to use some non - uniform hatches to obtain something similar to the attached image. https://images.adsttc.com/media/imag...jpg?1499273017 The building probably has a gradient hatch, while the lawn, and the concrete plaza, what hatch did they use for it? Thanks in advance.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,760
    For the term "Hatch" to be valid, one needs to assume this is a Cad drawing of some sort, and it probably is, but not necessarily.
    The two curved roof buildings at the lower right are gradient hatches, all the rest are all solid fill hatches of different shades in the same color range. Each different shade is a separate hatch with a distinct border. For the lawn areas and trees, the linework (hatch Boundaries), using splines for curves, are the same color as the hatch so the lines don't show up.
    The very nature of hatches precludes the use of random patterns or more than one color with the exception of gradient fill. If you open a *.pat file with Notepad and look at the content, you will see a coded description of a small pattern that can be repeated to fill any given area, but there is only one pattern.
    Although your idea is a good one, one AutoCad hatch can only do one thing.
    You can however, produce a pdf, jpg, or png file of your drawing and open it in a program as simple as MS Paint to apply many different colors in random patterns with far greater speed, and far less work than hatching in AutoCad
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,540
    Quote Originally Posted by Dana W View Post
    Don't forget about "Superhatch". I know, it sounds made up, but you can use images (or blocks/xrefs which could contain images) as the base of your "hatch pattern".
    R.K. McSwain
    CAD Panacea | twitter
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,643
    Well raster images can be added to AutoCAD and one can also use raster (jpgs) as hatch patterns with the SuperHatch tool. You can also bring the drawing into Photoshop, Illustrator, Corel Draw, Inkscape and other graphic programs. One older program was M-Color which would allow one to colors, hatches and such with AutoCAD layers.
    https://www.m-color.com/
    Good luck
    Edit: RK beat me by a minute with SuperHatch. +1 for bringing it up as I have gotten good results with it over the years.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  5. #5
    Forum Newbie
    Construction
    Electrical 2016
    Apr 2018
    2
    Thank you!
  1. Make Watercolor type Rendering of 2d House
    By Don Roberto in forum AutoCAD Drawing Management & Output
    Last Post: 18th Mar 2011, 07:39 pm
  2. Getting information from Non Uniform Blocks
    By MikeMc52 in forum AutoCAD General
    Last Post: 5th Feb 2011, 07:26 pm
  3. Uniform Scale LOCK
    By Handy Man Dan in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Sep 2010, 02:48 am
  4. Uniform distributed load
    By lochie50 in forum Autodesk Inventor
    Last Post: 9th Feb 2010, 03:39 pm
Tags for this Thread
