kareemuddin Posted April 22, 2018 Share Posted April 22, 2018 Hello All, We have been using a lisp program which runs on the .dxf or .dwg exported from the Design engineer to create additional detailing and extract the quantity with our existing lisp (design software, anonymous name =x) however we have recently changed / switched to new Design software (anonymous name =y) and unfortunately the lisp doesn't run on the exported files from new design software = y It would be of great help if someone can help me by editing or re write the lisp so that it works on exported files using new design software Quote Link to comment Share on other sites More sharing options...
dlanorh Posted April 22, 2018 Share Posted April 22, 2018 Hello All,We have been using a lisp program which runs on the .dxf or .dwg exported from the Design engineer to create additional detailing and extract the quantity with our existing lisp (design software, anonymous name =x) however we have recently changed / switched to new Design software (anonymous name =y) and unfortunately the lisp doesn't run on the exported files from new design software = y It would be of great help if someone can help me by editing or re write the lisp so that it works on exported files using new design software You'll need to attach an example of the new exported file and the old lisp. Quote Link to comment Share on other sites More sharing options...
kareemuddin Posted April 22, 2018 Author Share Posted April 22, 2018 here I am attaching the exported files from new software/program and old lisp Tendon X.dwg tools_2c.lsp Quote Link to comment Share on other sites More sharing options...
dlanorh Posted April 22, 2018 Share Posted April 22, 2018 here I am attaching the exported files from new software/program and old lisp It would seem that the output from the new design program is completely different from the output of the old design program. Which objects is it supposed to work on, and on which layer(s) "Current_plane_Tendon"? I don't fully understand the lisp or what it is trying to do, as i don't speak spanish, however there are multiple references to: Layer "Ram_Concept_Element" and none for "Current_plane_Tendon". Layer "Ram_Concept_Element" doesn't exist in the drawing "AcDb2DPolylines" where the items on "Current_plane_Tendon" are of type "AcDb3DPolylines" or "AcDbLWPolylines" Block selection looking for block name "BLOQUE1" - No blocks are define in the drawing. Quote Link to comment Share on other sites More sharing options...
