Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    Multi-disciplinary
    AutoCAD 2016
    Nov 2017
    72
    Default aligning text within text editor.
    so i have been looking for some time now to try and find something that will be able to help me with this. i want to be and to have the text within Mtext to be aligned right, center or left. the only way that i can see to do that right now is to double click, highlight the text and then selection it from the ribbon.
    i have tried to use textalign command and that just doesnt seem to move the text to the right, center or left.
    anyone know of a lisp out there that you would be able to just choose left, right or center and then click the text that you want to change?
    thank you all
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    835
    All you need to do is toggle justify in the properties palette ?
    Full Member
    Multi-disciplinary
    AutoCAD 2016
    Nov 2017
    72
    yes, i just am the type that doesnt like using the palette. just thought i would see if there is something out there that could make things a little faster
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    835
    Quote Originally Posted by dnovember99 View Post
    Fair enough .. I'll hammer out some code in a bit if someone else does not jump in
  5. #5
    Full Member
    Multi-disciplinary
    AutoCAD 2016
    Nov 2017
    72
    oh awesome! the other thing that i am not a fan of with using that palette is if you have Mtext and dont have the box out to a certain size when you do hit justify from right to left it moves the text. so that is another extra step. not sure if that can be considered also or not. if not all good. just thought that i would throw it out there.
  6. #6
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,531
    Try this:
    Code:
    (defun c:mj ( / g i l s )
        (if (setq s (ssget "_:L" '((0 . "MTEXT"))))
                (repeat (setq i (sslength s))
                    (setq l (cons (entget (ssname s (setq i (1- i)))) l))
                (princ "\nAlter the alignment using the numberpad <done>: ")
                (while (and (= 2 (car (setq g (grread nil 2)))) (< 48 (cadr g) 58))
                    (setq g (cons 71 (cdr (assoc (cadr g) '((49 . 7)(50 . 8)(51 . 9)(52 . 4)(53 . 5)(54 . 6)(55 . 1)(56 . 2)(57 . 3))))))
                    (foreach x l (entmod (subst g (assoc 71 x) x)))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  7. #7
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    835
    Nice Lee .. here's another quick one.
    Code:
    (defun c:just (/ j k s)
      (setq j '("TL" "TC" "TR" "ML" "MC" "MR" "BL" "BC" "BR"))
      (initget 0 (apply 'strcat (mapcar '(lambda (x) (strcat x " ")) j)))
      (cond
        ((and (or (setq
    		k (getkword
    		    (strcat "\n[" (apply 'strcat (mapcar '(lambda (x) (strcat x "/")) j)) "]: <TL>")
    	      (setq k "TL")
    	  (setq s (ssget ":L" '((0 . "mtext"))))
         (foreach e	(vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
           (vla-put-attachmentpoint (vlax-ename->vla-object e) (1+ (vl-position k j)))
    (vl-load-com)
    Last edited by ronjonp; 11th May 2018 at 06:54 pm. Reason: *added all justification options
  8. #8
    Full Member
    Multi-disciplinary
    AutoCAD 2016
    Nov 2017
    72
    Quote Originally Posted by Lee Mac View Post
    Try this:
    Code:
    Mr. Mac, thank you for this. i was playing around with it and i noticed that on the key pad (9)is bottom (6) center and (3) top and then the other side (7) bottom (4) center and (1) top.
    i think that is to where you want to have the leader showing at. am i thinking correctly? i was thinking more along the lines of when you double click on the text, highlight the text and while in text editor just above "paragraph" you can select the "justify" right, left, center, etc.
    i was talking with someone and they told me that just using a macro could work. here is what i was given.
    Code:
    ;; Justification Macros
    (defun _justifyIt (justify title / ss)
      (princ (strcat "\nSelect *Text to " title " justify: "))
      (if (setq ss (ssget "_:L" '((0 . "ATTDEF,MTEXT,TEXT"))))
        (command "_.justifytext" ss "" justify)
    (defun c:JL (/) (_justifyIt "_L" "Left"))
    (defun c:JR (/) (_justifyIt "_R" "Right"))
    i am noticing that this doesnt work on all mtext. it depends on the justification point it has. and/or it will only work when the text is looking like this. i sure hope that i am making sense with this.
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,531
    Good stuff Ron
  10. #10
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    835
    Good stuff Ron
    Cheers!
  1. Text hard to read in the Civil 3D text component editor?
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 1st Jun 2015, 02:20 pm
  2. Text hard to read in the Civil 3D text component editor?
    Last Post: 6th Feb 2013, 03:20 pm
  3. Aligning text around a circle/arc
    By Matho in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th May 2009, 06:03 pm
  4. arc with text aligning???
    By avieira in forum AutoCAD Beginners' Area
    Last Post: 30th Apr 2009, 02:23 pm
  5. Underlining text in the Multi text editor.
    By cad07 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Feb 2007, 11:38 pm
