Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    813
    You could add JT as an alias to JUSTIFYTEXT in Acad.pgp using the ALIASEDIT Express Tool or make a Ctrl+J Shortcut Key for it under Keyboard Shortcuts in the CUI
    One more option is to add a 'Justify Text' flyout to both 'Mtext Object Menu' and 'Mtext Objects Menu' Under 'Shortcut Menus' in the CUI with commands for each option like:
    Name TL
    Macro
    Code:
    $M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_justifytext;TL;,^C^C_justifytext;TL)
    and another Justify Text flyout to both 'Text Object Menu' and 'Text Objects Menu' Under 'Shortcut Menus' in the CUI with commands for each option like:
    Name Left
    Macro
    Code:
    $M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_justifytext;TL;,^C^C_justifytext;Left)
    I can use the shortcut Ctrl+J, enter JT, or right-click selected text and pick 'Justify Text' to select the justification.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  2. #12
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Quote Originally Posted by dnovember99 View Post
    Mr. Mac, thank you for this. i was playing around with it and i noticed that on the key pad (9)is bottom (6) center and (3) top and then the other side (7) bottom (4) center and (1) top.
    You should find that the justification is set as follows: 7=Top-Left, 8=Top-Center, 9=Top-Right, 4=Middle-Left, 5=Middle-Center, 6=Middle-Right, 1=Bottom-Left etc.
    This is confirmed in my testing - is this not the case?
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  3. #13
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    997
    Quote Originally Posted by Lee Mac View Post
    Numeric layouts can differ. At my work couple of colleagues are from Belgium and they prefer their own keyboard layout so having to type something on their keybord is well, challenging to say the least. But nice little routine, both from you and ronjonp.
  4. #14
    Full Member
    AutoCAD 2010
    May 2009
    68
    @ Lee
    If that were synonymous with text, now it works only with MTexte
    Würde das auch mit Text gehen, jetzt funktioniert das nur mit MTexte
  5. #15
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Quote Originally Posted by dober View Post
    @ Lee
    The following should work with both -
    Code:
    (defun c:mj ( / g i k l s )
        (setq k
                (49 ((71 . 7)) ((72 . 0) (73 . 1)))
                (50 ((71 . 8)) ((72 . 1) (73 . 1)))
                (51 ((71 . 9)) ((72 . 2) (73 . 1)))
                (52 ((71 . 4)) ((72 . 0) (73 . 2)))
                (53 ((71 . 5)) ((72 . 1) (73 . 2)))
                (54 ((71 . 6)) ((72 . 2) (73 . 2)))
                (55 ((71 . 1)) ((72 . 0) (73 . 3)))
                (56 ((71 . 2)) ((72 . 1) (73 . 3)))
                (57 ((71 . 3)) ((72 . 2) (73 . 3)))
        (if (setq s (ssget "_:L" '((0 . "TEXT,MTEXT"))))
                (repeat (setq i (sslength s))
                    (setq i (1- i)
                          x (entget (ssname s i))
                    (if (and (= "TEXT" (cdr (assoc 0 x))) (= 0 (cdr (assoc 72 x)) (cdr (assoc 73 x))))
                        (entmod (setq x (subst (cons 11 (cdr (assoc 10 x))) (assoc 11 x) x)));  (subst '(73 . 1) '(73 . 0) x)))
                    (setq l (cons x l))
                (princ "\nAlter the alignment using the numberpad <done>: ")
                (while (and (= 2 (car (setq g (grread nil 2)))) (< 48 (cadr g) 58))
                    (setq g (cdr (assoc (cadr g) k)))
                    (foreach x l
                        (foreach y (if (= "MTEXT" (cdr (assoc 0 x))) (car g) (cadr g))
                            (setq x (subst y (assoc (car y) x) x))
                        (entmod x)
  6. #16
    Full Member
    AutoCAD 2010
    May 2009
    68
    Thank you perfect LEE
    As always tooles Lisp
    Danke perfekt LEE
    Wie immer tooles Lisp
  1. Text hard to read in the Civil 3D text component editor?
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 1st Jun 2015, 02:20 pm
  2. Text hard to read in the Civil 3D text component editor?
    Last Post: 6th Feb 2013, 03:20 pm
  3. Aligning text around a circle/arc
    By Matho in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th May 2009, 06:03 pm
  4. arc with text aligning???
    By avieira in forum AutoCAD Beginners' Area
    Last Post: 30th Apr 2009, 02:23 pm
  5. Underlining text in the Multi text editor.
    By cad07 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Feb 2007, 11:38 pm
