Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Senior Member
    AutoCAD 2013
    Aug 2014
    128
    Question Error in opening the stl file!
    Hi Dear members
    I've got a strange problem when I'm going to import a *.STL file as follows:
    I would greatly appreciate it if you kindly tell me how to solve this problem.
    kind regards,
    hamid
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,312
    Can you tell us what the problem is? What error message are you receiving?
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Senior Member
    AutoCAD 2013
    Aug 2014
    128
    Quote Originally Posted by Cad64 View Post
    Dear Cad64, thank you for your attention!
    i've got the following message:
    "can not find the specified drawing file. please verify that the file exists". it also should be noted, when I confirm the mentioned message nothing happens.
    best regards,
    hamid
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,312
    How are you attempting to open the stl file? I thought Autocad could import stl files, but it appears that it cannot.
    Take a look here for some options: http://www.cadforum.cz/cadforum_en/i...tocad-tip11311
    Facebook:
  5. #5
    Senior Member
    AutoCAD 2013
    Aug 2014
    128
    How are you attempting to open the STL file? I thought Autocad could import STL files, but it appears that it cannot.
    thanks for your response, but unfortunately my problem was not solved. I try to open it either by double-clicking or running by the IMPORT command.
    I've generated the STL file from one of the CFD softwares. I've tried to do the mentioned tips in the link, I've selected the desired STL file. after that, the answer I receive is that "0 points processed".
    best regards,
    hamid
  6. #6
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,312
    You can't open or import stl files into Autocad, so double clicking the file or running the Import command will not work.
    Can you provide the stl file? I can try opening it in one of my other programs and see if there is a problem.
    Facebook:
  7. #7
    Senior Member
    AutoCAD 2013
    Aug 2014
    128
    You can't open or import STL files into Autocad, so double-clicking the file or running the Import command will not work.
    Can you provide the STL file? I can try opening it in one of my other programs and see if there is a problem.
    sure, I've attached the desired STL file in the following link. also, I've created the simple geometry by Autocad to see what happens, but it doesn't work as before.
    https://drive.google.com/file/d/1prH...7SivsiCFX/view
    with the best wishes
    hamid
  8. #8
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,312
    I imported your stl file into 3D Studio Max, and it imports with no problem, but it seems like the object may have some issues? Not sure if it's supposed to have that jagged edge? Anyway, I exported a .dwg file. See attached.
    Facebook:
  9. #9
    Senior Member
    AutoCAD 2013
    Aug 2014
    128
    yes, you're correct. it has been composed of jagged edges. I don't think that's a problem because I can't even open simple geometries. I really don't know where is the problem. have you succeeded to import the desired file into AutoCAD?
    Could you please tell me what you think about this issue.
    Many thanks
    hamid
  10. #10
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,312
    Like I said before, you can't open or import stl files in Autocad. You need to use a different program to import the stl file and then export out a dwg or a dxf file.
    I just tried this free online conversion tool and it worked. I was able to upload the stl file and convert it to dxf format: http://www.cadforum.cz/catalog_en/stl2dwg.asp
    Facebook:
  1. error opening file
    By mish in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 19th Mar 2013, 09:42 pm
  2. Opening File, Fatel Error
    By Michael Burchmore in forum AutoCAD General
    Last Post: 27th May 2010, 12:49 pm
  3. Error while opening a DXF file converted from PDF
    By saadicarnot in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 2nd Nov 2009, 11:24 am
  4. error in opening DXF file
    By ali888 in forum AutoCAD Drawing Management & Output
    Last Post: 27th Oct 2008, 04:46 am
  5. Error when opening DXF file generated by another program
    By Kirill2005 in forum AutoCAD Drawing Management & Output
    Last Post: 24th Oct 2005, 06:23 pm
